Results 1 to 6 of 6
Thread: Butcher Block Finish from Lowes
    Jun 2012
    Laurinburg NC
    316
    I had some of this from a project a while back,....maybe a yr ago..I decided to try it on a bowl I used a small piece of tee shirt.I have put several light coats on it but cant get a good smooth finish finish.Each time I have sanded the bowl back nice and smooth but still no luck.I tried applying more finish..had same results..If I put a small amount it streaks and with more still not smooth I dont know what to do !! ??
    http://www.lowes.com/pd/WATCO-Butche...ck-Oil/3153369
    4,698
    So according to the MSDS its ~50-75% mineral spirits (aka stoddard solvent), and 1-2% xylene (another solvent) and .. something else.
    http://www.rustoleum.com/MSDS/ENGLISH/241758.pdf
    So lets see if we can figure out what the "something else" is because that's the important bit.
    The older MSDS gives the rest as an alkyd "long oil" (aka an alkyd resin varnish)
    http://www.highlandwoodworking.com/m...rblock-oil.pdf
    the msds from home depot agrees
    http://www.homedepot.com/catalog/pdf...279a11fe3c.pdf
    So basically you have an alkyd resin varnish in a lot of mineral spirits and a bit of xylene to thin it out. I'd treat it as a wiping varnish.
    I mostly use this technique: http://www.finewoodworking.com/how-t...g-varnish.aspx
    although I skip the steel wool most of the time and just sand back with 400 before the final coat (or two) and the rub the nubs off with some crumpled brown paper bag.
    If its going on too thick, thin it back out a little with some mineral spirits first (not mineral oil - spirits).
    Yorktown, Virginia
    5,002
    I use that stuff as a base coat on my end grain cutting boards. It's so thin that if I slather a heavy coat on one side it will penetrate the entire block in a day. I usually do two coats, one per day, saturated on both sides then let it dry, after which I rub in a few coats of a paste made with five parts Mahoney's utility walnut oil finish and one part beeswax gently melted together. My unproven theory is that the thinned varnish fills up the end grain pores in the wood and along with the walnut oil/wax surface coating will mitigate against water penetration. I have not tried it on bowls as I felt it too thin for a film forming finish.
    Jun 2012
    Laurinburg NC
    316
    Ill sand this back and then put a good coat on it and see what happens.At this point I just want to get finished with this bowl and move on Thanks !!!
    4,698
    It did say it was a long oil resin as well which means it would be pretty slow to cure and build. So I guess give it plenty of time if you want any surface build.
    Apr 2009
    Outside the beltway
    5,250
    This thinned out stuff , if you gt a can of Japan Dryer and put "A" drop or 2 in about 10 OZ's it will quicken the drying time rapidly.
    ::: Andrew Wyeth :::
    colonialrestorationstudio.com
  1. The butcher block project...
    By John Pollman in forum Flatwork Project Showcase
    Last Post: 04-17-2013, 04:47 PM
  2. End Grain Butcher Block For Counters?
    By Matt Hutchinson in forum General Woodworking Q&A
    Last Post: 12-23-2012, 08:33 PM
  3. Butcher Block - Salad Oil as finish/sealant
    By Stephen Volner in forum Finishing School
    Last Post: 04-03-2008, 02:01 AM
  4. how would you flatten an old butcher block?
    Last Post: 02-17-2007, 02:54 PM
  5. Butcher Block Oil...............
    By Mark Rios in forum Finishing School
    Last Post: 11-16-2006, 10:01 PM
