Results 1 to 10 of 20
Thread: helllllllp!!!!
    Dec 2008
    falcon heights, minnesota
    5,610
    helllllllp!!!!
    tonight the steel rod that sets up the clamping of the rip fence of my porter cable 8312 table saw snapped for the third time. i've been looking all over the place for a replacement rip fence, but with no luck. any ideas out there? trust me, when that thing shears like that, it does it with a bang.
    benedictione omnes bene
    www.burroviejowoodworking.com
    30,017
    Not sure what your budget might be for a replacement, but I sure have been happy with the Incra fence I put on my Ridgid TS.
    17,472
    start over, SAW
    East Freeetown, Massachusetts
    3,020
    You say 3-rd time?
    There is a problem.
    Are you maybe over tightening?
    I wonder about the mechanical design. I sure would like to take it all apart and maybe redesign it with better materials. It is probably cold rolled steel. Some stronger steel is most likely a good choice as well as a larger diameter rod.
    I would contact Porter Cable engineering and explain the problem to them.
    Are you sure about the model number. I can't find anything on a PC 8312(?). I would like to see the saw so that I might recommend a solution.
    Dec 2008
    5,610
    sorry, kind of cross eyed when i tapped that one in glenn. it is really a 3812. i've had it for about 12-14 years now, and still runs good. i just want to replace the fence. this is the saw, didn't get the stand though.
    5,321
    3812 maybe? If that's it, eReplacement Parts says the rod is obsolete, and unavailable, so a home built version will be needed.
    Dec 2008
    5,610
    that's why i figured that replacement of the whole thing would be best, as almost all parts are obsolete. last time i picked one up (about 3-4 years ago) he said he had 2 more left, and wouldn't be getting any more.
    Yorktown, Virginia
    5,015
    If the fence works, then I like Leo's approach. Take it apart and replace the rod with something more sturdy. Any metal fabricator/machine shop should be able to pop one of those out in less than an hour @ $60/hour.
    Thomasville, GA
    5,994
    If your budget allows, you can't go wrong with an Incra fence, as Vaughn mentioned.
    Bill Arnold
