Results 1 to 10 of 21
Thread: picture frames project
    Dec 2008
    falcon heights, minnesota
    5,610
    well, the time was nigh to start getting rid of some of the small scrap (and make some money too hopefully). there is a type of picture frame that i made a few years back, and i decided to make another 12 for the upcoming craft shows. today i got the parts for the uprights cut to size, and the blanks for the frames themselves cut and planed. then i decided that it was too darned hot for anything else. i'll probably finish up the other parts tomorrow.
    Attached Thumbnails Attached Thumbnails 001 uprights cut to size.jpg   002 frame parts cut to width and planed.jpg
    benedictione omnes bene
    www.burroviejowoodworking.com
    Dec 2008
    5,610
    got a bit more done with the frames today. got all of the tops, bottoms, and sided cut to length. after that, cut all of the notches, and tenons. tomorrow, it will be the cutting of the feet, and the base rails.
    Attached Thumbnails Attached Thumbnails 003 frame sides cut.jpg   004 frame tops and bottoms cut.jpg   005 notches cut.jpg   006 shoulders cut.jpg   007 tenons finished.jpg
    Yorktown, Virginia
    5,022
    Looking good, Dan. Stay cool.
    East Freeetown, Massachusetts
    3,022
    Love it.
    Great progress pics
    Dec 2008
    5,610
    got a bit more done today. cut and planed the blanks for the base rails and feet. then cut all the base rails and feet. all that is left for them, is to cut the notch in the feet for the base rail tenons, then cut the top corners of the feet at a 45 degree angle.
    Attached Thumbnails Attached Thumbnails 013 base rail and feet blanks.jpg   014 base rails and feet cut.jpg
    Dec 2008
    5,610
    cut the notches in the feet today, and i hope to get the tenons on the rails done today too. next will be the fun part of cutting the angles on the feet.
    Attached Thumbnails Attached Thumbnails 015 notches cut in feet with jig.jpg
    Dec 2008
    5,610
    got the tenons cut for the base rails, and did a test fitting. rerigged the jig for cutting the angles on the feet, and cut those too.
    Attached Thumbnails Attached Thumbnails 016 base rail tenons cut.jpg   017 base example.jpg   018 jig for cutting angles on feet.jpg   019 all feet angles cut.jpg
    Dec 2008
    5,610
    last thing i did today, was a quick setup of one of the frames. still have to knock off the extra from the rails, cut mortises and tenons, and chamfer the tops of the uprights. drilling the holes for the hinge pins (nails), and for the backing. turning out pretty good so far.
    Oliver Springs, TN
    1,726
    Looks great Dan.
    Jan 2009
    Carthage,Mo
    887
    Neat. Very good.
    David
  1. picture frames
    Last Post: 09-27-2014, 05:19 AM
  2. Picture Frames for the 4th
    By glenn bradley in forum Flatwork Project Showcase
    Last Post: 07-02-2010, 07:08 AM
  3. flame birch picture frames
    Last Post: 04-13-2009, 02:19 AM
  4. Picture frames - Amatorski methods
    By Niki Avrahami in forum Flatwork Project Showcase
    Last Post: 03-18-2008, 09:14 PM
  5. Picture Frames-Profitable?
    By Travis Johnson in forum General Woodworking Q&A
    Last Post: 10-28-2007, 05:50 AM
