- Reno NV
Looks great Rennie!
Well, I wouldn't run out and start them both at the exact same time, but if the combination of amps fit then it should work. If the amps fit and it's throwing breakers, it may be that the breakers are getting old and tripping too easily and need replacing. I've had a couple that have done that in my home panel where they weren't even drawing close to the breaker's capacity, but it was tripping early as it was just worn out/defective.
I'd still suggest running new circuits as you will need them in the future to the existing panel area as you would if it was a 100 amp panel, then if it's an issue get the panel upgraded later.
...If the amps fit and it's throwing breakers, it may be that the breakers are getting old and tripping too easily and need replacing. I've had a couple that have done that in my home panel where they weren't even drawing close to the breaker's capacity, but it was tripping early as it was just worn out/defective...
Been giving it a lot of thought. I will likely dump the idea of using the old 8 place panel with double and triple breakers and install a new 20 place panel. The thought of trying to navigate all those wires for 14 circuits in an 8 place panel. It is also an old panel with no isolated ground like the newer ones, if I understand that correctly.
The local Menards has a 20 place 100a panel that comes with half dozen breakers for $56. Seems a good deal and not much more than the total cost for all the double and triple breakers I would need to set up the old box.
I'll run everything I can think of back to the panel even though I might not need them all right away as you suggest. Good advice.
Rennie, couple points, what gauge wire do you have going into that panel. You need it heavy enough not to have a volt drop when you running all you hope to be able run at once.
And i would open those boxes and check for damage or missing bits before you end up not being able to claim. Before you put them aside to finish the shop.
I got this 30 gal airtight drum from a fellow in Paw Paw,
from the looks of it I would guess about 30 gallonsThat should work great, although I can't help but wonder how much sauerkraut that would make.
