Results 1 to 8 of 8
Thread: Lets See Your Taper Jig !
    WNY, Buffalo Area
    873
    If you have made your own taper jig for your table saw, I'm interested in seeing your pictures.
    I'm kicking around a few ideas for a future project that might require some tapered cuts. I currently don't have a taper jig, but am considering making one. Any ideas are appreciated!
    I get the Woodworkers Journal eZine emails and the most recent one had free plans for a taper jig, but it looks very complex.
    http://www.woodworkersjournal.com/ez...s/legtaper.pdf
    www.tinyurl.com/thewoodshoppe
    Zushi, Japan
    739
    http://familywoodworking.org/forums/...?t=1748&page=2
    This is from Fine WW. Can't remember the issue but not so far back. I built it for the project I am working on now because I wanted to do four sided tapered legs.
    9,109
    I plan on making the one Alex mentions. It looks a little ungainly but if you watch it in action on finewoodworking.com, it does a nice job and looks easy to use. I agree that WWJ version looks way over thought out.
    FWW - http://www.taunton.com/finewoodworki....aspx?id=24155
    WNY, Buffalo Area
    873
    Application of Taper
    Is it possible to take a rectangular board and taper it from both ends toward the center with a taper jig? Or would this be best done on a bandsaw?
    This is rough example of what I want to do....
    San Antonio, Texas
    765
    Sean, it really depends on how may of these you need. If you only need one or two, you'd probably be better of using the bandsaw and then fine tuning them with the necessary sanders, files and scrapers. However, if you need a number of these I'd make a hardboard template using the process I described above. Then you can tape it to your stock and cut them out using a router w/bushing and a straight bit. You'll still have to work the hard angles by hand, but it would save you a boat load of time.
    9,109
    Make a jig and use a router with a spiral bit similar to cutting out inlays?
    Smithville, TX
    358
    Here's a little one on the bandsaw:
    Here's a big one on my slider (is a slider cheating?):
    Another one for the bandsaw for tapering things too tall for the TS:
    Mini Max Tool Acquisition Mediator.
    "An old man to most kids and a young man to those who are dead."
    www.samantics2.com
    9,109
    Sliders are definitly not cheating. Great stuff as always, Sam.
  1. Taper Jig - Straight Rip Jig
    Last Post: 09-14-2014, 04:19 PM
  2. Taper Jig - Blade Choice?
    By David Agnew in forum Jigs and Fixtures
    Last Post: 01-11-2014, 08:38 PM
  3. loose morse taper
    By gary doby in forum Turning Tool Questions and Show & Tell
    Last Post: 01-09-2008, 02:27 AM
  4. interesting taper method
    Last Post: 07-02-2007, 05:53 AM
  5. Taper Lock
    By Jr Strasil in forum Neander Tool Questions and Show & Tell
    Last Post: 01-21-2007, 01:29 AM
