Results 1 to 2 of 2
Thread: Dado adapter/insert
    Dado adapter/insert
    Long time ago in another galaxy........ I am trying to re-arrange my shop and finding things I did not know I had!; I have this contraption, 4 discs made of aluminum, 2-11/16" in diameter numbered from 1 to 4, the two outside discs are #'s 1 and 4 with numbers around the circumference starting at #0 to the left numbers 1 to 37 in odd numbers, to the right numbers 2 to 38 in even numbers and ending with #39, discs #1 and 4 have indentions that mate with discs #2 and 3, 2 and 3 are cut in an angle and by mating these discs the saw blade is at an angle and would cut a groove like some dado heads; I assume that according to the number combinations you could vary the width of the groove, there is not a name of the product only its stamped pat. pend. I believe this came from a Company that was selling kits for making your own table saw.
    Hopefully someone remembers this Company just out of curiosity.
    Thanks, Martin
    5,172
    Sounds like a wobble dado blade. A number of companies made/make them. Hate them myself. Think it is a very dangerous blade. Threw mine out an dgot a stacked set instead. Much more comfortable with those.
    Problem as I see it (or don't see it) is that the cut is wider than what my eye perceives as the spinning blade. Very disconcerting.
  1. Monster Hollowing System Upgraded Adapter
    Last Post: 08-07-2014, 04:02 PM
  2. Corian vac adapter advice needed
    Last Post: 04-16-2010, 08:56 PM
  3. Head stock spindle adapter question
    By Jim C Bradley in forum General Woodturning Q&A
    Last Post: 04-28-2009, 03:33 AM
  4. lathe chuck adapter insert
    By Frank Fusco in forum Old Ads
    Last Post: 07-19-2008, 03:48 PM
  5. A hose adapter question please.............
    By Mark Rios in forum New Tools
    Last Post: 07-07-2007, 04:21 PM
