Results 1 to 6 of 6
Thread: Just Some Quick Storage
    15,808
    I recently moved some of the stuff around by my computer and I have this area that is kind of open, I need to make the best use of my space as it is so small.
    Just a quick and dirty little pull out drawer unit.
    The bottoms of the draws will be 5.5 mm plywood, these will act as the runners, so I cut all my slots in the sides of the box in one go.
    The two sides of my box
    The back and some fronts to go
    Basically that's it done, just some finger holes and then install it
    Installed. The drawers are too high to look into, but with the bottoms acting as the runners, they come out easily and can be set on the bend to dig through.
    Not a lot of everyday stuff will live in these drawers, but it is good to have the storage just the same.
    Total start to finish took less than an hour.
    Thanks
    10,606
    I like it
    That'll work.
    Constantine, MI
    7,892
    Hmm. I would not store loose tennis balls in them, but I could see them working for many other items!
    www.wrworkshop.com
    Sep 2015
    Central valley, calif.
    112
    Letting the drawer bottoms act as runners works well for shop cabinets. It looks like the carcass is made from what we called "lumber core" back in the day. It should stay nice and straight. We haven't been able to get it here for many years.
    15,808
    Quote Originally Posted by william watts View Post
    Yes I've used this design before, it is quick and easy for shop cabinets.
    The wood is lumbercore and I hate this stuff for building cabinets, the is VERY soft and does not hold a screw well at all, but for the white melamine covered stuff it is the only option. I used up some scraps from making the workstation in the monitor room in the last office remodel, the stuff is expensive and I hate to just toss it.
  1. quick box
    By Darrell Bottoms in forum Flatwork Project Showcase
    Last Post: 12-22-2010, 09:33 PM
  2. Quick ?
    By Stephen Bellinger in forum Turning Tool Questions and Show & Tell
    Last Post: 02-07-2010, 01:33 AM
  3. Quick Overhead Storage - a recap
    Last Post: 12-20-2009, 06:19 PM
  4. quick fix
    Last Post: 06-11-2008, 06:14 PM
  5. Replies: 11
    Last Post: 11-26-2006, 04:25 PM
