Results 1 to 10 of 15
Thread: Electrical question - 220v
    East Freeetown, Massachusetts
    3,022
    If I have a device that is 220v I need a switch to turn it on and off.
    The 220v circuit is 2 hot wires - really nothing else is needed. A ground is a nice to have, and I will ground.
    Do I need to break both hot leads? I think I should break both. In a 110v I need to only break only one lead.
    Sooo, on a 220v circuit, what does a switch look like, assuming relatively low amperage (2a) What does a switch look like for 15a
    Is this a double pole single throw switch (DPST)?
    Can you post links to Amazon possible switches for those 220v circuits?
    Independence, Kentucky
    1,355
    Leo, you have it right DPST is what you want, Carling makes a very good switch , a little more costly, but a good product.
    https://www.amazon.com/s/ref=nb_sb_s...ST%2Caps%2C144
    13,452
    Correct, break both leads using a DPST switch. Looks like Charles has you hooked up on the link.
    13,361
    If you want to live on the edge, you could get one of these "safety" switches
    4,699
    You can also get wall switches
    https://www.amazon.com/Leviton-CS220.../dp/B000U39UC6
    https://www.amazon.com/Leviton-MS302.../dp/B002MPQ51O
    Push button switches
    https://www.amazon.com/Woodstock-D41.../dp/B005W17GZE
    Paddle switches
    https://www.amazon.com/Woodstock-D41.../dp/B005W17FRS
    The reason you want double pole is that in a 110v circuit only one "leg" is hot - so if you interrupt that leg you can't complete the circuit with either the neutral or the grounding wires. You also want to interrupt the hot leg in that case, if you find a switch that is switching on the neutral its a hazard condition because the circuit is still energized and needs to be fixed asap. With 220 both wires are hot, so you can complete the circuit from either of them to either a grounding wire or to the earth itself (because that shares a common ground). This is also why its a BAD IDEA to do things like wire together two 110v switches or breakers, because if one trips and the other doesn't the load can all go through the untripped side overload the rest of the circuitry (i.e. the wire) quicker than the breaker can trip causing a flash and thus a fire.
    4,699
    Aww, that's fine looking. Be sure to throw those with verve so they aren't left doing the arky sparky dance. I've welded a couple of those shut by being hesitant
    3,022
    FANTASTIC - Great suggestions.
    I know what to do now
    3,022
    Ahhhh YES - Double Pole Single Throw.
    This is what I had in mind.
    4,699
    One thing to consider (based on the type of equipment you're using)... is a magnetic interlock switch. Basically they will shut off if the power is disconnected and NOT turn back on if the power comes back. They are substantially more expensive though. I don't know your use case here, but it might be a consideration depending on the possible projected failure modes....
    For example:
    http://www.grizzly.com/products/Magn...campaign=zPage
    http://woodworker.com/1hp-5-8amp-1ph...su-923-950.asp
    Grizzly has a nice selection of switches overall..
    http://www.grizzly.com/search?q=(categoryid:275010)
    If you're looking for a more central maintenance disconnect something like this
    http://www.homedepot.com/p/GE-60-Amp...0RCP/100674085
    actually works pretty well.. It would be used if you have an piece of equipment that you want to completely cut _all_ power to for infrequent periodic maintenance (commonly things like hard wired air compressors or dust collectors). The nice thing about this sort of disconnect is that you can LOCK the disconnect so no one can re-energize it without removing your lock (common practice in industrial settings - search "lock out tag out" for more). I wouldn't use it for something you needed to disconnect more than say monthly as the interface isn't really rated for a high duty cycle.
    Thomasville, GA
    5,998
    I've used this switch on several tools for about three years. They work great!
    Bill Arnold
  1. Electrical Question
    By Michael Tulak in forum Off Topic Discussion
    Last Post: 05-04-2015, 08:55 PM
  2. Electrical Question
    By Sayer Fancher in forum Off Topic Discussion
    Last Post: 12-13-2014, 06:17 PM
  3. An RV Electrical Question
    By Paul Douglass in forum Off Topic Discussion
    Last Post: 04-29-2014, 08:33 PM
  4. Cutting blanks on Bandsaw - 220v wiring help / question ?
    Last Post: 11-04-2012, 02:11 AM
  5. Electrical question
    By Bob Gibson in forum Off Topic Discussion
    Last Post: 08-27-2011, 03:30 PM
