Stuart Ablett
- Tokyo Japan
The video...
I think the carbon cloth and epoxy is worth the effort.
Cheers
Cheers
...I'm going to get some more wood and try thinner strips, maybe only a few millimeters thick...
I've had good results using laminations that are about 3/32" (~2mm) thick. What glue are you using? Titebond, etc., tends to creep, and seems a bit 'soft.' Powdered recorcinal glue allows more opwn/working time, and dries overnight to a very hard and strong joint, with no creep. Expensive and messy, there's always epoxy.
Jim, when you do this, do you run the thin pieces through the thickness planer?
No. I get a really smooth cut off my Laguna Resaw King blade, so I can usually glue directly from there. If they need any touch-up at all, I take a very light pass through the Performax drum sander.
I haven't done enough bending to call myself an expert, but I start with very thin wood, and never use white or yellow glue since it creeps (my first choice is urea resin glue that I use for veneering). I have never done any steaming.
How thin does the wood have to be? Just enough that it doesn't break when bent, which depends on how severe a bend and how wide a board, but 4-5 mm would be a common starting point. I use a carbide blade in a big bandsaw, so the cut is smooth enough that I can get 4-6 "veneers" before a quick pass on the jointer to give me a new starting reference surface against the bandsaw fence. The urea resin glue is gap filling which gives forgiveness for the slight roughness of a bandsawed surface (in fact with shop cut veneers, I glue the sawn side to the substrate and sand the finished surface after the glue dries).
Charlie do you mean that Gorilla glue stuff?
Urea resin is what he meant.![]()
...I want a 10 degree bend, but I'm concerned about some rebound after it is glued up, so I was thinking (always dangerous) to make the form 11 degrees or even 12 degrees, anyone care to comment on that idea?...
