Results 1 to 10 of 14
Thread: Brad Nailer or Pin Nailer
    May 2009
    Lafayette, Indiana
    2,380
    I'm going to be putting up some 1/4" panels in my home and have decided to buy a nail gun and air compressor for the job. I've never needed an air gun before and may never use it after this project. I'm looking at two different guns from Harbor Freight. The first one is an 18 gauge brad nailer that used brads up to 2". http://www.harborfreight.com/air-too...ler-68021.html
    The other one is a 23 gauge pin nailer http://www.harborfreight.com/air-too...ler-60241.html
    although it will only use nails up to 1".
    I guess I'm not real clear on the difference between a pin nail vs brad nails.
    I think I'm going to also get a small air compressor from them...again I don't have much use for one. They have a small 3 gallon oiless compressor in either a pancake style tank or hot dog style tank. I've read that these compressors are big enough for the small job that I will be doing.
    http://www.harborfreight.com/air-too...sor-61615.html
    http://www.harborfreight.com/air-too...sor-97080.html
    Thomasville, GA
    5,992
    For the paneling, you'll need the brad nailer. Brads for the gun have a small head, whereas a pin as used in a pin nailer has no head. Even using the brads, it would be best to run a bead of adhesive behind the panels. A pin nailer is best used for attaching small trim while leaving an almost invisible hole behind.
    Any small air compressor will be more than adequate for a nailer.
    Bill Arnold
    5,319
    Pin nails have no heads - they're just pins.
    Brad nails have a small head, and have better holding strength than pins.
    Different tools for different jobs...
    For your job, I'd use the 18 gauge brads, long enough to go through the panels and plaster,, and maybe " or so into the wall studs. 1" brads oughtta do it.
    Jan 2009
    Carthage,Mo
    881
    Sometimes you can get small compressor with nail gun. I picked a Black Hawk up from the big blue store with nailer included. Didn't need it but it's now on my shelf with the other larger gun. I do like to use them for putting up trim. Don't have to fight hammering and holding. Goes quicker.
    David
    Dec 2008
    WI
    72
    I agree with everything Bill Arnold said.
    Dave
    May 2009
    Lafayette, Indiana
    2,380
    Great! Thank you all for the information. Tomorrow Harbor Freight has 25% off coupons too.
    Sent from my iPad using Tapatalk
    5,319
    Quote Originally Posted by Tom Baugues View Post
    ...They have a small 3 gallon oiless compressor in either a pancake style tank or hot dog style tank. I've read that these compressors are big enough for the small job that I will be doing...
    I have the pancake-style one - the one that develops 150psi - and it does a great job, even with bigger nailers than what you'll be using. It's a bit noisy, but all oilless compressors are, so that's not a concern for me. (the wife's opinion might differ...)
    May 2009
    Lafayette, Indiana
    2,380
    Good to know Jim. Thanks for the info.
    17,470
    tom, you should check out the box stores before harbor freight. you might get a free gun package for less and a name brand to boot.. check out cpo outlets as well
    Nov 2015
    Central North Carolina
    96
    I don't know how large your nailing job is, but if you have a shop air compressor you can do small nailing jobs with these air nailers using one of the tire inflator type storage tanks as a power source. Fill it up at your shop compressor and then use it with your nailer. A ten gallon tank will let me drive 50 or more brad nails before I have to go back to the shop to re-fill the tank. I changed the fitting on my tank to an air line quick connect fitting, so I can plug in either the original tire inflator line and fitting or one of my air hoses into the tank. I also made up a double male air fitting so I can fill the tank faster from the air hose in my shop, but make certain that your tank comes with a valve, so you can shut it off before disconnecting the shop air line and remove the double male fitting. Doing this can be a bit dangerous if you disconnect the air hose without shutting the valve off, so be careful. I now use this tank for every small job that needs compressed air and is relatively close to my shop, but too far away to run an air line from my big shop air compressor. It would be perfect if you will be driving less than a few hundred brads and your shop air compressor is within walking distance.
  1. Replies: 0
    Last Post: 04-16-2012, 01:43 PM
  2. Brad Nailer and Finish Nailer problems
    By Doug DeVore in forum General Woodworking Q&A
    Last Post: 11-09-2010, 04:23 PM
  3. Brad Nailer
    By Sal Cangialosi in forum New Tools
    Last Post: 02-01-2010, 04:08 PM
  4. Replies: 1
  5. Pin/Brad nailer
    By Porter Bassett in forum General Woodworking Q&A
    Last Post: 02-10-2008, 03:17 AM
