Results 1 to 10 of 14
Thread: The Shed Re-build
    5,172
    The Shed Re-build
    So the thing is in the bed of my pickup in a bazilion pieces. No problem getting it apart but there will issues re-assembling it. The previous owner was ham-handed installing some of the screws. So of course there are numerous holes that have been stripped out.
    This is a Lifetime plastic shed. The plastic is polyethylene. Can I use a plastic wall anchor for the stripped out holes or has someone got another idea?
    Independence, Kentucky
    1,354
    Can you go to a larger screws/ Fasteners, to solve the problem?
    12,251
    I am thinking if you used plastic plugs there is nothing really for them to grip on except the thin wall from blow molded plastic.
    I would say Charles has the answer.
    Oct 2007
    Nova Scotia, 45°N 64°W
    1,245
    Depending on access in back, you might try something in the auto body line. I'm picturing the little sheet metal clips that act like a nut for the screw threads to grab.
    5,172
    They screws are already #12's. The head fits in a recess, so larger screws may not work. The panels are double walled so there is no access to the back side for automotive clips. Plastic wall anchors have a splined shaft that should keep them from turning once seated in the buggered hole. Keep the ideas coming. I have a floor to build to put this on so there is time to sort it out.
    13,360
    What about rehabbing the screw holes with some jb-weld? Mix it up, fill up stripped hole, then come back after it dries and drill a correct sized hole for the fastener.
    13,442
    I was thinking the same as Charles. Does the screw need to go into the recess if going larger? Maybe just a washer under the head and call it good with a little longer screw?
    5,172
    Brent had it.
    Cool trick using Teflon tape to keep from gluing the screw in.
    12,251
    Cool tip there Brent.
    I think that guy in the video took the "don't get this stuff on your fingers" to the extreme.
    I have used this type of epoxy and my experience is , yes wear some gloves, but mix it with your fingers. The little heat transfer and kneading between fingers gets it mixed better and helps activate the two parts properly. It looked to me like his did either not dry completely or adhere completely before he backed that screw out.
    4,552
    A Turn N Time
    Frog Pond Guitars
  1. The new shed
    Last Post: 06-05-2016, 03:06 PM
  2. A Shed
    By Stuart Ablett in forum Carpentry and Construction
    Last Post: 12-11-2013, 04:35 PM
  3. How not to build a shed
    By Mike Stafford in forum Off Topic Discussion
    Last Post: 04-07-2013, 06:13 PM
  4. Steel shed vs wood shed
    Last Post: 01-04-2011, 02:37 PM
  5. I need a shed.
    Last Post: 05-12-2010, 09:22 PM
