Results 1 to 10 of 24
Thread: My Shopful of Old Iron
    here are some pics of my shopful of oldies, i'll post pics of individual machines over the next couple of days
    so pic out and id the oldies!!
    some will be obvious, some are more obscure Canadian machines but they were all available stateside, primarily at montgomery wards
    Los Angeles, CA
    2,668
    Hey! what is that Dewalt chop saw doing in there?
    Nice stuff you got there.
    that dewalt chopsaw is almost an oldie as well, it would actually be allowable on owwm under their rules(20+ years old, not asian origin)
    its 21 years old and made in the US!
    4,748
    I'd be suspicious if you used that shop or not if there wasn't that bucket of shorts in the one picture, the whole place is way to clean
    Its interesting how much more attractive the lines are on a lot of the old iron. I can't decide if its inherent or if its conditioning but things like that bandsaw sure are pretty. Thanks for sharing!
    first is my 1940's Delta/Rockwell 1160 tilt top table saw
    i bought this a few years, it had been well taken care of but when i first saw it, it was a pile of parts on a pallet!! what a jigsaw puzzle
    the bearings had been replaced but with the wrong ones so the blade was way off centre in the slot and the blade wobbled like crazy.
    new bearings and truing up of the blade back washer solved those issues.
    i was fortunate to find NOS bearings, spindle and many other parts, most of which i didnt need
    i dont think the 1160 ever came with the cast iron base, i think that base is from a jointer. but it fits perfectly.
    the motor is a 30 yr old 2 hp, runs on 240 and is buried deep in the cast iron base.
    one issue with the 1160 is that its tippy because of the small footprint. i resolved that with the shopfox mobile base, its bolted to the cast iron base and is expanded to be larger on the right side
    tilties are somewhat different to use, but i dont even think of it anymore. the table also goes up and down for depth of cut which can be a nuisance if you use outfeed support, i use the ridgid fliptop stand when i need it.
    i does get used, everyday, and its not usually that neat and tidy. dust collection is always a pain, even more so on old stuff
    its a double car garage and the flooring is "wood" laminate, very easy to sweep and gentle on tools and old knees!
    this is my main jointer, late 40's beaver 3800. beaver tools were designed and made by the callander foundry in guelph, ontario, canada. rockwell bought the foundry and the beaver line of tools in 1954. many rockwell and delta tools were made there after that
    ive rebuilt 3 or 4 of these jointers, this one came out of an old very wet barn, a very rusty pile of parts. interesting design, the cutterhead and pulley are one piece and there is no spindle. the cutterhead runs on a pair of tapered roller bearings inserted into the main casting. a simple cleaning and repack with fresh grease brought them back. note the fence tilt system, that must have cost a fortune to make. its a shortbed jointer, the extensions were an option. rebuild was simple except for rust removal, tables were coplaner, all the parts were there
    its powered by an old wagner repulse induction motor(has starting brushes), i rebuilt that, although not much to do except a decent cleaning. the motor is mounted in the forward position to allow for a dc system under the jointer. the cabinet is shopmade using castiron legs that were available from beaver at the time
    as far as pretty lines, i'll get a pic of my three bandsaws, modern ryobi, 1935 beaver and the 1915 crescent side by side!
    for those who dont frequent the turning forum, here is my wood lathe
    its a 1940's henry power tools aka craftmaster "boat tail". 36 inch bed, 14 inch max dia. inboard
    powered by a Hoover 1hp with a 5 speed jackshaft and 4 speed head stock, motor is reversible(switch on the motor's side)
    4,748
    And a homemade hand wheel on the lathe unless I miss my guess. Looks like a sweet little turner.
    Love the cabinet under the jointer. That's some quality work and really fits in well with the overall antique equipment collection. The fence is indeed an interesting design, looks dang solid.
    Last edited by Ryan Mooney; 10-01-2016 at 11:10 PM. Reason: a word... some not summer
    ive built several of those cabinets over the years, different sizes for diferent machines. down to two of them now, the jointer and a taller(longer leg) under my scrollsaw
    the "handwheel" on the outside of the headstock is actually a quick change faceplate, made by OneWay, there's another smaller faceplate to fit the same hub hanging on the cabinet. it does function as a handwheel too, although usually as a hand powered discbrake!!
    4,748
    That works
    I didn't see anything setup on the outboard side for turning there? Might just be missing the setup though...
  1. Some Old Iron
    By Ted Calver in forum Old Iron
    Last Post: 06-29-2015, 01:34 PM
  2. Old Iron
    By Bart Leetch in forum Old Iron
    Last Post: 05-18-2011, 03:52 AM
  3. not really old & not much iron
    By Paul Hubbman in forum Old Iron
    Last Post: 03-04-2010, 04:05 PM
  4. Iron man
    By Chuck Beland in forum Off Topic Discussion
    Last Post: 09-14-2008, 11:11 AM
  5. Can you say old iron???
    By Bart Leetch in forum General Woodworking Q&A
    Last Post: 01-27-2007, 04:30 PM
