Results 1 to 10 of 11
Thread: Recycled Cedar into a Small Outdoor Table
    i spotted this table design a few years back in american woodworker, plans are on their website
    lots of jigs and router trammel works!!
    the cedar is really nice stuff, it came from a cottage i renovated a couple of years ago. the cottage was built 70 or so years ago and framed entirely in 2 by 3 cedar. the growth rings are really tight,, so that all four faces appear 1/4 sawn. all the pieces for top so far are actually 1/4 sawn
    here is the outer ring glued up, 12 segments with splines
    Click image for larger version
    the pie shaped centre section added
    just one of the router setups, this one cuts the outer ends of the centre section pieces
    i'll get some pics, of the various setups, but detailed info is in the AW plans. i'll find the link to them
    next step is space the centre section pieces out, glue them in, then cut a hole for the "hub"
    im building the table 1/2 sized from the plans, the origanal was a "sit to eat" type, i wanted small side tables
    sorry for the lousy pics, i cant find the base piece that fastens the camera to the tripod
    here's the link to the plans, note my top is 1/2 the size
    http://www.popularwoodworking.com/pr...st-patio-table
    Jan 2009
    Carthage,Mo
    912
    That is awesome. A lot of planning for the little honey.
    David
    im actually planning on building four of them, get the bugs worked out and the jigs made up on this one
    then i'll do three at once
    Dec 2008
    falcon heights, minnesota
    5,642
    good thing going there steve! to paraphrase my grandma, as long as you've got the jigs set up, just as easy to do a dozen, as to do one.
    benedictione omnes bene
    www.burroviejowoodworking.com
    i'll get some pics of the various jigs and setups today.
    i stated with nominal 2 by 3 cedar, actually 1 3/4 by 2 3/4, so a little larger than typical construction stuff these days. picked through the pile to find all nice close grained stuff(easy pickins!). i cutup blanks for all the pieces(long enough for at least two pieces so i wasnt jointing and planing shorts).
    dressed them all to 7/8 with bandsaw(the old crescent), jointer and planer then cut all the circle segment parts to approx. length and same with the pie shaped pieces
    simple stuff so far!
    the pie shaped pieces were all tapered on both sides, first at 7.5 degrees then the second side at 15. this kept the nice straight grain in a radial pattern in the final tabletop.
    i did all the tapering using the tablesaw and my crosscut sled with a small fence added. here's the sled with the fence set for 15 degrees for the centre section parts
    10,615
    What a fun project !!!
    and the finished table. pretty fussy getting all those pie shaped pieces evenly spaced
    made the legs by laminating 6 pieces of cedar over a form
    Sep 2007
    Plainwell, Michigan
    4,864
    That looks fantastic Steve, you really got the jigs set up just right
    Yorktown, Virginia
    5,079
    Pretty darn classy, Steve.
    873
    Too nice to use! Inside only, not in the elements. Nice job, Steve!
    Mack C. in Brooklin ON
    It feels great to sell a pen,
    I am a proud supporter of
  1. A fun recycled project, pine coffee table for my nieces new college apartment
    Last Post: 11-25-2011, 08:24 AM
  2. outdoor cedar
    By craig shields in forum Finishing School
    Last Post: 07-09-2011, 09:53 PM
  3. Small Cedar hollow form
    By Dennis Ford in forum Lathe Project Showcase
    Last Post: 02-20-2011, 06:27 PM
  4. Small Cedar chest
    By Ron Roase in forum Flatwork Project Showcase
    Last Post: 07-08-2010, 01:39 AM
  5. 2 small tables-end grain lamp/end table, small storage coffee table
    Last Post: 06-01-2009, 11:06 PM
