Results 1 to 10 of 24
Thread: Just Curious-Always Wondered
    Mar 2015
    Parker County, Texas
    981
    I have always wondered, and never asked or tried to find out, if there is some sorta rule of thumb that dictates what depth a vessel is a bowl or a dish. Generally, if it the piece turns out to have a depth of 1" or less I have called it a dish. Sounds silly seeing I've been turning all these years, but I never knew if there was a general rule of thumb on that. Anybody know or are there any thoughts on it?
    Tellico Plains, Tennessee
    4,156
    Can't answer your question in absolutes, but sort use the same criteria... if it looks like a plate or platter, I call it that, otherwise, it's a bowl.
    Chuck
    Tellico Plains, TN
    4,406
    I dunno?
    I'm not sure there is a hard and fast rule, somewhere in there it transitions to a plate as well.. but where to draw the line seems a bit arbitrary depending on all the proportions of the piece.
    I guess if it walks like a duck and quacks like a duck we can call it a duck even if its a robotic killing machine bent on world domination. Or if it looks like a bowl, works like a bowl then you could still call it a plate if that sold better... I suppose.
    15,657
    My very loose rule is that if it cannot hold enough soup for a meal, its a dish or a plate platter, but I'm talking about something soup bowl in diameter and up, not a very small bowl like you would put a side dish in.
    Told you it was a loose rule
    Dec 2008
    falcon heights, minnesota
    5,205
    or it could be a variant of the rule a former supreme court justice said about certain magazines, you'll know a bowl or dish when you see it....
    benedictione omnes bene
    www.burroviejowoodworking.com
    Oct 2009
    Harrisburg, NC
    135
    I don't think you can set any rules as it can depend on the intended use.
    In general, I think of a bowl as having a rounded bottom where a dish would have an almost flat bottom regardless of the diameter and height.
    If by dish you mean plate/platter then I think it depends on the base also. An item may be 8" diameter and 2" deep; if it has 1/3 as a base and curved bottom I would call it a bowl, if it had 2/3 -3/4 base and a flat bottom I would call it a platter/dish.
    All tyranny needs to gain a foothold is for people of good conscience to remain silent. Thomas Jefferson
    4,156
    In the final analysis, does it really matter... it it will hold M&M's, it all good.
    Chuck
    Tellico Plains, TN
    Mar 2015
    981
    Now, Chuck! That answer makes all the sense in the world, and I can totally relate to it. All good answers which basically tell me that there ain't no real rule of thumb on it. My curiosity has been satiated. But, I did like what Ryan said about the robot.
    Feb 2013
    Clyce, Texas
    150
    The difference is that a bowl concentrates your M&Ms at the bottom of the bowl, but you have to chase them around a plate.
    Mar 2015
    981
    Aha!!! Now I know whether it is a bowl or dish. The ultimate test is the M&M Test. My mind can totally wrap around that.
  1. Curious - Do you know?
    By Sharon Korn in forum Off Topic Discussion
    Last Post: 03-23-2015, 05:39 PM
  2. Have you ever wondered ...
    Last Post: 03-05-2011, 12:07 AM
  3. If you ever wondered how it was done...
    By Rod Upfold in forum Off Topic Discussion
    Last Post: 03-01-2010, 01:39 AM
  4. Curious
    By Robert Farmer in forum General Woodworking Q&A
    Last Post: 09-07-2007, 06:11 PM
  5. curious about plantation shutters
    By Fidel Fernandez in forum Neander Woodworking Q&A
    Last Post: 04-29-2007, 09:50 PM
