Results 1 to 10 of 13
Thread: Electric Workshop Heater
    East Freeetown, Massachusetts
    3,072
    I just ordered this heater from Amazon
    https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
    It is 220v 31a. I will put in a 40 amp breaker in the main panel for this.
    What wire should I use?
    3,072
    Pretty sure #8, but do I need 8-2 or 8-3
    The 8-2 has 2 hots and one ground total of 3 wires in the casing
    The 8-3 has 4 wires in the casing. I don't think I will need to get 110v out of the cable.
    13,619
    Depends on if there is a case ground, which you would need 8/3.
    Sent from my SM-T710 using Tapatalk
    13,619
    Well, had a little more time to google, and I think this is the owners manual for the unit you ordered. If so, 8/2 should suffice, according to diagram 7B, page 4...
    http://www.marleymep.com/sites/defau...-11195-000.pdf
    3,072
    Yep - shows it on Fig 6 page 3 also.
    I will get the 8-2 wire.
    Sacramento, CA
    1,367
    I have the 5kw version of that heater. It's very good. You should have no trouble with it at all!
    Jason Beam
    Sacramento, CA
    3,072
    Quote Originally Posted by Jason Beam View Post
    Jason, you have been in my shop, and you know my winters are colder than yours. I trust your judgement.
    Sacramento, CA
    1,367
    Quote Originally Posted by Leo Voisine View Post
    Yep - our space is pretty similar - as long as you're insulated, the 7.5kw should do plenty. I keep mine on the lowest setting on the worst days and it can easily keep it over 75 in there on 30 degree days. I have R15 in the walls and ceiling and an R13 garage door. About 450-500sqft.
    The thing I love about it over radiator type heaters is that i don't have to maintain a temperature. I can go out there when it's cold, kick the heat on and have the forced air warm ME up before anything else and that helps. Once the slab and all the iron come up to temp, it hardly runs at all - maybe for 2 minutes every 15 ...
    You should have no problem
    Jason Beam
    Sacramento, CA
    3,072
    I have R13 in the walls and the ceiling has R19. The windows are all low E double pane and quite efficient. The Garage doors are made in Canada where they know about cold.
    My floor in winter does not warm up. It's too cold to be barefoot in winter.
    I still have my 60,000 BTU propane heater and that will stay for many years.
    I just want to minimize the propane usage. I would LOVE to eliminate the propane.
    The electric is basically free, so it's a lot cheaper than the propane.
    13,430
    Really wish my garage was insulated. Would be cool to have something like that out there to warm things up.
  1. Infrared heater
    Last Post: 12-05-2013, 03:52 PM
  2. toe kick hot water heater
    Last Post: 06-05-2012, 11:37 PM
  3. Hot Water Heater -It is all about up-charges
    By Bartee Lamar in forum Off Topic Discussion
    Last Post: 03-18-2008, 02:52 AM
  4. HF I.R. heater OK for shop?
    By Jim C Bradley in forum General Woodworking Q&A
    Last Post: 11-01-2007, 04:05 AM
