Results 1 to 8 of 8
Thread: lesson from hammers and levers
    5,266
    The used plastic shed is almost not worth the money savings. One place I tried was I put it on an existing concrete slab. Of course, it was not dead flat. Bigger problem that I thought it would be. Been shimming as advised in the instructions. Using my biggest dead blow hammer as my long handled steel sledge is in a trailer in another town one hour round-trip away. Not enough oooph!
    So a trip to Harbor Freight 10 minutes away and $8 later I have a 2' wrecking-bar, Great lever. Boosted up the edges and shoved in the shims. One more side to go but it is in the sun so it will have to wait until Monday morning when I can do it in the shade. Can't work in full sun. I get light headed and can't see. Back in the house and hydrating as I type.
    Lesson: when a bigger hammer doesn't get the job done, a longer lever is called for.
    Jan 2009
    Carthage,Mo
    944
    If it doesn't fit force it.
    David
    30,237
    Great lesson, Carol.
    Jun 2007
    4,945
    We will have to tell ole Archimedes ghost that!
    However, long lever and no place to stand does not work too well.
    Enjoy,
    JimB
    Carol, can't you stay out of trouble?
    VOTING MEMBER
    13,467
    Levers and big hammers!
    Not worth the savings because it was used? Or because of the need for a perfectly level base?
    Going to go take a look and see where I want to put mine. I will make sure to make a nice level base for it based on your feedback.
    13,741
    Good lesson, between the tools, and knowing when to call it a day.
    Yorktown, Virginia
    5,139
    .... One more side to go but it is in the sun so it will have to wait until Monday morning when I can do it in the shade. Can't work in full sun. I get light headed and can't see. ...
    My solution to too much sun. This system is very mobile and works great for me in the garden.
    One of these, strategically placed:
    http://www.lowes.com/pd/Blue-Hawk-Po...x-5-ft/4780965
    Then slip one these down over the post:
    http://www.lowes.com/pd/Garden-Treas...in-L/999901391
    5,266
    Thanks, Ted, but a post through the concrete would probably not be appreciated by my current landlord!
    For Brent: The old style shed had a snap in fit for the wall pieces that did not snap in easily or even with considerable force. I had to modify the slots to make it work. Think the plastic got less flexible as it aged. The new sheds have a drop-in slide over tab connection. Works MUCH easier. Other than that, I think the Lifetime shed from Costco is a good deal and looks nice when done.
    And, yeah, dealing with a wavy concrete pad did not help things at all. Still have some shimming to do tomorrow morning in the shade to get the door to close decently, but nearly there. All in all, cost gobs more time than it should have.
  1. Juggling Hammers
    Last Post: 02-06-2012, 06:36 PM
  2. Lesson Day
    Last Post: 01-16-2011, 04:18 AM
  3. First Lesson
    By Bruce Pennell in forum Lathe Project Showcase
    Last Post: 06-07-2008, 01:13 PM
