Results 1 to 10 of 10
Thread: Rail and Stile profile cutting
    Matt Dunlap Guest
    Steve Clardy Guest
    #6001
    Turn the diagram upside down.
    Adjust bits to suit.
    I don't see a single bit that is reversable for both cuts.
    Just the pair.
    http://www.routerbits.com/cgi-router...29766_19160+81
    Steve Clardy Guest
    Thinking.........................
    Steve Clardy Guest
    Matt. Do you have any fluting bits? 1/4" straight, round bottom
    17,515
    or you could
    just buy the bits set for your self and do the work quicker and you keep the bits and they get the door frames,, you both win and maybe they would cough up half of the bit set just to get it done quicker. they could put you to better use elswhere.
    535
    Go old fashioned, make a real tenon rather than a stub and just miter or cope the profiles at the intersection. Door would last longer that way anyhow.
    Central CA
    797
    Matt, I can't tell from the pic that you've provided...is the profile "round" like Steve's example of the 6001 bit set? Or is it more like this profile:
    If not, would this bit set with this profile work?
    Thanks, Mark.
    Custom Bonehead.
    My diet is working good. I'm down to needing just one chair now.
    "Just think how stupid the average person is, and then realize that half of them are even stupider!" --George Carlin
    Central CA
    797
    Well, DANG then!!! I had the set that I pictured above that I was going to send you. Sorry it won't work for you.
    Hope you get it worked out.
    Thanks, Mark.
    Custom Bonehead.
    Central CA
    797
    Soooo...it looks more like this one then?
    If so, then this Freud bit set at Amazon looks to be a little less expensive if you decide to buy one. Free shipping as well.
    http://www.amazon.com/Freud-99-260-1.../dp/B0000225XS
    hth
    Thanks, Mark.
    Custom Bonehead.
    1,289
    Hey Matt,
    Tell the boss you will get the bits now and he can buy them from you in July.
    DT
  1. Rail and Stile
    By Steve Southwood in forum Designs, Plans and Sketches
    Last Post: 08-09-2011, 08:56 PM
  2. seeking rail & stile bit set
    By Bill Simpson in forum General Woodworking Q&A
    Last Post: 04-27-2009, 08:51 PM
  3. Replies: 0
    Last Post: 11-11-2008, 04:48 AM
  4. SketchUp Ogee Rail & Stile Template Available
    By Jeff Wright in forum Designs, Plans and Sketches
    Last Post: 05-15-2007, 12:27 PM
  5. Rail and Stile Question
    By Ed Nelson in forum General Woodworking Q&A
    Last Post: 05-10-2007, 07:04 PM
