Page 2 of 2 FirstFirst 12
Results 11 to 12 of 12
Thread: The (mortise) Jig is up!
  1. #11
    13,427
    Well, I do believe this might just work. Found a scrap of maple and gave it a test.
    Drilled out the center with a spade bit then Went part way down from the top with a router collar.
    Then took it out, put it in a vise and cleared out from the other end with a bottom bearing bit.
    A little burning on the corners, but it's hidden so not a huge deal.
    Gave it a half hearted attempt to square it up and I'll be darned if it didn't clear it out pretty easy.
    I think this will work.
ID:	97521Click image for larger version.
  2. #12
    13,607
    That looks like it works pretty darned well.
    Sent from my SM-G920P using Tapatalk
  1. Mortise Jig
    By william watts in forum Jigs and Fixtures
    Last Post: 11-15-2015, 04:21 AM
  2. How I Use the Mortise Pal
    Last Post: 02-03-2015, 01:20 AM
  3. Original Mortise Pal - $99
    Last Post: 05-02-2009, 09:44 PM
  4. Mortise Pal and Through-mortises
    Last Post: 09-06-2008, 10:49 PM
  5. $30 off Mortise Pal
    Last Post: 08-30-2008, 01:09 AM
