Results 1 to 9 of 9
Thread: Angled Mortise and Tenon, Chairmakers Saw and Tenon Clamp
    faced with the prospect of making 6 dining chairs with angled M/T joinery, i came up with this jig and saw via a google search
    they are called a chairmakers saw and a tenoning clamp
    the clamp is pretty simple, 3/4 plywood, glued and screwed, then a clamping jaw with a bolt, nuts and washers. and a handle
    then the shoulder cutting saw:
    its just a block of white oak scrap, a japanese folding saw blade and an old plane knob and tote, all bolted together
    these make cutting the angled shoulders easy and accurate
    here's a couple more shots of the saw.
    i started with a scrap of white oak, 2" by 10", about 1 1/2" thick
    sliced it to give a 5/8 thick bottom, jointed and planed the bottom for a consistent thickness
    drilled some holes for 5/16 bolts(be careful drilling the very thin blade)
    a junky old hand plane gave up its knob and tote, a couple of squarehead bolts(makes it look old!!) and nuts and washers
    this is the saw from lee valley, i always have a couple of these around and a spare blade or two
    http://www.leevalley.com/en/Wood/pag...884,42898&ap=1
ID:	97581Click image for larger version.
ID:	97582Click image for larger version.
    the cheek cuts were done on my tablesaw with my shopmade tenoning jig
    the angled mortise was cut using my beaver drillpress and hollow chisel mortising attachment. note the angled scrap under the work piece
    and here is my tenoning jig for the tablesaw, nothing fancy, just some scrap 3/4 plywood. note that i added hardwood to the sides of my rather narrow old delta jetlock fence for more stability for the jig. the jig just cuts the cheek cuts, the shoulder cuts are done as above
    im at the "prototype" stage at the moment, practising and setting up with scraps
    i'll be building this chair(6 actually): http://www.popularwoodworking.com/oct15/slat-back-chair
    the article has some info on the clamp and saw
    5,017
    The shoulder saw is very clever. Stealing that one. Love the pull saw blades also.
    Thanks for posting.
    Yorktown, Virginia
    4,746
    Elegant solutions to the problem. Very creative.
    not my idea!! origanally a french design a century ago
    ive used a couple of times to get the hang of it, got some improvements to do
    the saw registers on the clamp top surface, so the walls need to be thicker. also the saw needs to be longer although the blade is long enough, the saw keeps "falling" over the edges and the knob and tote hit the tenon
    so a new and improved version is coming!
    10,551
    Ingenious
    5,017
    Quote Originally Posted by steve morris View Post
    I look forward to it. Take lots of pictures while you build it. It could become a tutorial here. We have a place for those.
    I am building a house and need all the tricks and tips I can find.
    Thanks.
    4,568
    That's a clever idea alright! Thanks for sharing it along.
    Lee Valley link got mangled somehow:
    http://www.leevalley.com/US/Wood/pag...884,42898&ap=1
    I'm thinking most of the flush cut japanese blades they sell (and quite a selection to choose from) would work pretty nicely as well.
    May 2010
    Orland Park, Illinois, USA
    262
    Steve, just a heads up as I looked into making a set of these chairs a while back. I found a couple of dimensional errors in the article and sketchup file. I asked Jeff and here is the response he sent me:
    Bob,
    Thanks for pointing out the problems. And my apologies that they crept into the plans.
    Most of these problems arose from my less than perfect drawing ability in SketchUp (I submit rough drawings), combined with editor turnover (Bob Land started work on the drawings, then the article sat for a while, and then Donna Hill took over).
    The drawing of the chair on p. 28 has the right dimensions: the back leg is 43 1/2Ē tall and the front legs are 17 1/4Ē. I donít really know why the different dimensions showed up, although I suspect itís because the leg angles back and the measurements may have been generated either on that angle or not.
    I didnít put the grid behind the leg in the back leg pattern, but that is obviously wrong. The leg shape is correct, though.
    I usually specify extra length for curved parts that will be bandsawn, so the 46Ē length in the cut list is about right. They should have put in that those were rough lengths, though.
    I hope that this helps.
    Best wishes,
    Jeff
    God luck with the project. Looking forward to seeing the progress.
    thanks for that info bob, i did come across that error when drawing out my rear leg pattern, my 48 inch piece of plywood was too short!!
    i will post a build thread when i actually get started in a couple of weeks, it will be my first "real" chair project
    im still working on perfecting the angled mortise and tenon joinery, just about there
    a minor improvement to the chairmakers saw, i made it longer. 18 inches overal actually, now the tote, knob or my hands dont hit the workpiece. also the blade is not bolted in anymore, just clamping the two blocks of oak together is plenty.
    also using the wedge for the angle(18 degrees in this case) as additional support, helps hold the workpieces for the side and back cuts
  1. Round Mortise with Square Tenon?
    By Bob Beasley in forum General Woodworking Q&A
    Last Post: 10-01-2015, 02:59 PM
  2. Mortise Tenon ?
    Last Post: 08-23-2011, 01:42 AM
  3. 114 Mortise & tenon joints
    By Jim DeLaney in forum Flatwork Project Showcase
    Last Post: 04-14-2010, 10:48 PM
  4. Three Quick Mortise and Tenon Questions
    By Chris Marlor in forum General Woodworking Q&A
    Last Post: 05-25-2009, 03:47 PM
  5. Mortise and tenon Q's... Workbench base
    By Brent Grooms in forum General Woodworking Q&A
    Last Post: 01-13-2007, 05:14 PM
