Results 1 to 8 of 8
Thread: how would you turn a burl
    11,874
    A friend showed my a nice walnut burl that he wants to try turning. The bottom is pretty attractive as it is and he doesn't want to mess it up with screw holes. And I agree. But, there is now the problem of how to hold it while turning the inside. This hunk is about 14" in diameter. All I can think of is a vacuum chuck but not everyone has one of those. What say the gallery?
    Frank....Your friend could try using a glue block.... and depending on what he wants to turn....the screw holes for a faceplate could be in the area that is going to be removed and wasted anyway.
    11,874
    Quote Originally Posted by Ken Fitzgerald View Post
    We want to leave the bottom natural. I could flatten and use the hot glue with aluminum faceplate thing but that would change the shape and appearance of the bottom.
    Try turning a glue block that has the basic shape of the bottom and then glue it up.....?
    Turn the rest between centers as much as possible before moving the tailstock.....?
    I don't know.....I'm just throwing out ideas.....trying to help......
    North Ogden, Utah
    348
    Frank, I turned one from an Australian burl that I think might be what you're talking about. I mounted this first on the top of the burl with a face plate. I then turned a hole/mortisse/whatevery you call it in the bottom deep enough to hold a round rosewood piece which became the tenon. After it was glued into the bottom it stuck out of the bottom about 3/4" and it had a tenon on it to hold it in my scroll chuck. I then held it in the chuck to turn the top/bowl of the burl and then parted off most of the rosewood tenon leaving just enough for a base that it sit's on.
    I'm not much at instructions but maybe the picture will help to see what I mean.
    Brentwood, TN
    294
    Mount it in a scroll chuck using a worm screw into the top portion?
    Put it between centers and turn a tenon or cut a relief for a chuck. Ya gotta hold the bottom with something in order to turn the inside.
    11,874
    Curt, Jim, that is what we will have to do. Leaving the bottom pristine doesn't appear to be an option. We gotta grab something. Curt, yours look terrific.
  1. Replies: 24
    Last Post: 07-04-2014, 02:04 AM
  2. My turn?
    By Jonathan Shively in forum Off Topic Discussion
    Last Post: 03-12-2014, 11:41 PM
  3. My turn...
    By Jim O'Dell in forum Off Topic Discussion
    Last Post: 08-06-2011, 02:01 AM
  4. Replies: 12
    Last Post: 04-07-2008, 04:33 PM
  5. FIRST TURN
    By Brad Hungler in forum Site Questions and Test Posts
    Last Post: 12-31-2007, 04:40 AM
