- Constantine, MI
Rather than hijack Brent's thread about the upgrading of his DC system I figured it best to start a new one. I purchased a Grizzly G0548ZP - 2HP Canister Dust Collector and the Super Dust Deputy cyclone. My intent is to use 6" PVC sewer/drain pipe for as much of the system as possible. Starting at the collector there is a mismatch in size. The PVC pipe is close to the same size so does not mate with the DC outlet and the fittings are too large. I've looked around on the web a bit and can't seem to find an adapter specifically made for this purpose.My thought is to use a no hub flex connector to connect the outlet to a short section of pipe and then connect the fitting to the pipe. Seems like it would work. I can't be the only person that has had to address this issue. Anyone have an idea on this?
