Results 1 to 10 of 30
Thread: What tools don't you have and why don't you have them (other than price)?
    Toronto, Ontario, CANADA
    2,332
    This is the subject of a thread that I started at a couple of other woodworking forums and, on both of them, the thread resulted interesting discussions. So, I thought that I would launch a similar thread here.
    I now have a very well equipped shop, but I find that I frequently surprise someone when I tell them that I don't have tool X, Y, or Z.
    I decided to put together a list of tools in this category -starting with the ones that are most obvious by their absence.
    1) Vise: Three months ago I got rid of a "mediocre" woodworking bench because it was not worth the room that it occupied. It had two "sub mediocre" vices. So, I find myself in the very strange position of not having a vice in my shop. All my life, even when we lived in a small apartment right after our marriage, I have had some sort of shop and, until now, there has always been vice in that shop.
    2) Woodworking bench: I have two general purpose benches and one Festool multi-function table (MFT) that I am making do with until I build a "proper" bench.
    3) Router Table or Shaper: These things scare me. But, I have recently decided that I will buy/make one in spite of this fear. That, along with the workbench, will be high up on my list of projects and/or acquisitions this winter.
    4) Combination square: I simply never got around to buying one and, as near as I can tell, there is nothing that combination square can do that I can't already do with some other tool in my possession.
    5) Powered Miter Saw: What with my table saw, my MFT, and a good non-powered compound miter saw, I simply can't justify getting one of these.
    6) Dado Blade for Table Saw: I much prefer making dados with a guided router.
    7) Wood Lathe: I might get around to buying of these some day but it won't be for a long time. It is more likely that I will get a metal lathe, a forge, and some welding equipment. I did a lot of metal work in high school and really liked it.
    8) Wood Moisture Meter: No excuse -I should have one.
    9) Laminate Trimmer: I will get one when I have a project that requires it. That will probably be this winter and I will probablty get the small Bosch unit.
    10) Drum Sander: I simply don't need one of these. I have three Festool sanders and they easily handle all my sanding tasks. I do have the parts for a 18 inch V-Drum sander from Stockroom Supply and plan to get around to making the portable case for it "one of these days".
    11) Mortising Machine: I have not had many projects where mortises were called for. The few mortises that I have needed to make were easily handled with drill and chisels. I expect that I will get one some day.
    12) Dovetail jig for a Router: So far, I not made much that required dovetails, so have made do with cutting these by hand. As is the case with a mortising machine, I expect that I will get one some day.
    13) Spray Gun: Up until now brushing and rubbing have worked well for me. I am only just starting to experiment with different ways of finishing projects and I expect that by this time next year I will have a spray gun.
    14) Power Nailer: I don't like using them. I feel that I can use better nails and do a better job when nailing by and. And, I am very fast. Maybe, if I was working where time was money I would feel differently.
    15) Compressed Air Machine: This is related to the previous two items.
    16) Downdraft Sanding Table: Because of the great dust control with my Festool sanders, this would be redundant.
    17) Radial Arm Saw: I am afraid of these and will never have one.
    18) Biscuit Joiner: I don't think that biscuits are any better than dowels. But, I might buy the Festool Domino Loose Tenon machine when it becomes available in North America because loose tenons are better than dowels.
    19) Belt Sander. I find them quite hard to control. And, now that I have a Festool Rotex 150 sander, a belt sander is redundant.
    Cheers, Frank
    frank, my answer is the same as it was last year.......i don`t have an infill plane......although id like to invest in several they`re a luxury item that i`m unable to justify to myself at this point in my life......tod
    Charleston
    917
    Tod,
    When you need one let me know and I will rent you one of the three tha I am lucky enough to have. They are very handy and are just an all around cool tool.
    N.E. Arkansas
    374
    I don't have a mortising machine but I do want one. If I knew what an infill plane was I would probably want one of those. The list would be rather long if I included everything that I really wanted to have but I just don't have time for the list right now. Gotta get my butt up and go to work. At least it is Friday.
    I once heard that cats and women will do darn well what they please and that men and dogs would do well to accept it and just go on.
    Constantine, MI
    7,954
    9) Drum Sander
    Frank,
    We all moan from time to time about not having 'something' in our shops. While reading through your list I found a few that are missing from my arsenal, but also realized how fortunate I am that many were already safely ensconced somewhere in my garage.
    I have an old (1920's) maple bench that I really like, but it's a poor substitute for a good assembly table. I have begun collecting the parts to build a router table and hope to get to it in the spring. It seems silly, but a good combination square has been on my list for a long time. Maybe I'm not thinking straight . As for a drum sander - might be nice, but there is no way I could fit one in and the use might never justify the cost.
    One thing not on your list that I have been eyeing for some months is a good shoulder plane. I love Arts & Crafts furniture so M&T's are a way of life in my shop. I could really put one of these to good use.
    In spite of what's missing, I have to recognize the tremendous blessings I already enjoy - not the least of which is a lovely wife that thinks everything I make is wonderful and tolerates my lust for tools.
    www.wrworkshop.com
    Steve Clardy Guest
    I guess the next most needed item is a line boring machine for shelf pins
    15,811
    Once you said "Other than price" my list went to near zero, cause if I had the money, I'd just buy what I need want, but the budget don't allow that.
    688
    Thanks for bringing this thread up again Frank. Its fun to think about. Mainly I'm holding off buying more toys - I mean tools, because of space and time. The shop is full and I don't have time to maintain any more tools - already spending too much time sharpening, calibrating, lubing, etc that I would rather spend working wood.
    There are some tools I just don't see the point to: radial arm saw, anything with lasers, and biscuit jointer.
    Trying to get rid of my scroll saw and accessories to make room for a Festool MFT.
    London, Ontario
    3,383
    I almost completely agree with Stu.
    However, Frank, I would change the original rules like this:
    " other than price or time "
    If I was retired, like some of the folks here, or if I didn't sleep, like Stu , I might spend more time in the shop. But as it is, I have a young family, and this is mostly just my hobby, so I don't spend as much time in the shop as others. So it isn't always just price that keeps me from buying things. Other things it's more: well I don't spend enough time to justify the investment.
    Interesting question.
    It seems in years past, everytime I thought there was a new gizmo or tool I just had to have, I would get it and never use it. Mortising Machine, Bigger planer, bigger jointer....
    Now I no longer look at tools like that.
    I am switching over to hand tools more and more, and get by on the tools I do have. Of the few new tools I want, I am looking at building my own...the satisfaction of producing them being almost as good as using them.
  1. Tools for sale I have more tools than room
    By Jack Holt in forum Classified Ads
    Last Post: 12-14-2012, 08:44 PM
  2. bandsaw price????
    Last Post: 09-15-2010, 11:44 AM
  3. With a price like that, we could not resist!
    Last Post: 04-01-2010, 04:35 PM
  4. HD again price gouging
    Last Post: 07-09-2009, 12:54 AM
  5. The Price is Right, right?
    By Chris Barton in forum Carpentry and Construction
    Last Post: 08-20-2007, 11:52 AM
