John D. Frigillana Jr.
- Kaneohe HI.
Fellow memebers,
Does anyone have a different method of finishing off a NIP bowl. I used the Danish Oil/Poly mix, did the multiple soaks with sanding in between soaks. I belong to the Honolulu Wood Turners and a method some use is to yput a couple coats of mineral oil, let dry and then use two coats of Dura Shield,let dry and then, apply a mixture of Poly/Penetrol.There are two bowls with the mineral oil and two that needs to be sanded down.
