- Springfield, Missouri
Got home to a fresh set of motor plates to install, these are 6mm thick instead of the original 3mm.
While working on those I also installed the end caps/supports for the extrusion.
I changed a few settings, tuned the motors and ran it through a couple of gcodes, performed well. Next up will be getting limit switches installed and deciding where to mount the laser driver.
