- Springfield, Missouri
I'll update with some pics of the printer later, I'll be adding the support brackets and belt tensioners tomorrow probably.
Here is a list of the items & links I've printed/used for mine.
Filament Guide: http://www.thingiverse.com/thing:1764285
Carriage Filament Guide: http://www.thingiverse.com/thing:1983882
Y Belt tensioner: http://www.thingiverse.com/thing:1492411
Y Cable Chain: http://www.thingiverse.com/thing:1915486
X Cable Chain brackets (used 10mmx20mm R28 commercial chain): http://www.thingiverse.com/thing:1975662
X Belt tensioner: http://www.thingiverse.com/thing:1683070
Frame Braces: http://www.thingiverse.com/thing:2069466
Belt Attachments: http://www.thingiverse.com/thing:1433295
Extruder Button: http://www.thingiverse.com/thing:1935151
Front Frame Brace: http://www.thingiverse.com/thing:1857991
Upright side Braces: http://www.thingiverse.com/make:295043
Rear Frame Brace: http://www.thingiverse.com/thing:1852358
Frame supports: http://www.thingiverse.com/thing:1872162
Main board cover: http://www.thingiverse.com/thing:1803120
Main board/Mosfet Mounting Plate: http://www.thingiverse.com/thing:1857006
Pi Mount: http://www.thingiverse.com/thing:2058740
Sensor Mount, shims cooling fan properly too (no longer used, but did cut the ring off and used the shim for the extruder cooling fan): http://www.thingiverse.com/thing:1907394
Sensor Mount on front radial fan: http://www.thingiverse.com/thing:2111157
Cooling ring nozzle: http://www.thingiverse.com/thing:1874390
Hold down brackets (replacing with frame braces): http://www.thingiverse.com/thing:1683033
Quick change spool holder (highly recommended): https://www.thingiverse.com/thing:1241566
New Y carriage plate: https://reprapchampion.com/collecti...ate-upgrade-v2-for-prusa-i3-reprap-3d-printer
The above plate requires spacers to clear the motor and a new belt connector: http://www.thingiverse.com/thing:1698328 & http://www.thingiverse.com/thing:863408
Attached is the Electrical Switch cover. There were several out there, but were for an older model of power supply, and they didn't quite fit the plugs that Brent and I each bought (Power switch used: https://www.amazon.com/gp/product/B00ME5YAPK/). I'll be pulling my cover off to add some exterior 12v power taps to use with fans and lighting. I currently have to take the power supply off the frame to remove the cover as one of the screws is behind the z motor and I had to use a self tapping screw there, so may be something to consider modifying.
View attachment electrical switch cover.skp
