- Thomasville, GA
I was trying to get a small item printed this morning and ran into an issue. It's a simple corner piece that needs a 3mm bolt through it. I did a layout in SU, exported the STL, imported it into CURA and it looked good. However, when I generated the gcode and printed it, the hole was not there. I used UGS to visualize the gcode and sure enough, no hole. So, I went back to SU, enlarged the hole to 3.5mm, went through the rest of the steps and it now shows it will create the hole. Ideas?
