- Thomasville, GA
The main things I've been printing are add-on for my Anet A8. I ran most of these over the weekend. Because of the length of time on each one, I could start a run then go inside and chill out for a few hours. OctoPrint allowed me to keep an eye on the printer from my recliner.
Frame stabilization parts that took a combined 15 hours to print.
Y-axis belt tension adjuster.
X-axis and Y-axis belt mounts. The factory options just aren't right.
Corner supports for the glass I use on my heat bed. These will allow the glass to sit in place without binder clips
Thumbwheels for bed leveling. One above the H-frame and one below. An M3 nut will press into each one. I'll drill out the threaded hole in the H-frame to allow the bolt to slip through.
Filament reel hubs and end bushings. Bearings press into each end of the bolt and fit onto the threaded rod that came with the printer.
I've saved these until today so I only have to take my printer down one time to make the changes.
