Tea Light LED Lithophane with wooden base as an anniversary present
Our Son and DIL are coming up on their 4th wedding anniversary, so I though I'd try to make them a little something.
I started with 3 pics of them and cropped them square, then copied them into a new wider photo with even spacing.
I then uploaded that to the http://3dp.rocks/lithophane/ site, and chose the Outer Curve option, then set it's size up to 200mm, and it's curve to 360 to make it a full cylinder.
Exported that and drew up a base for it in Sketchup a little larger than the inside diameter and placed them both centered in S3D to be fused together as it printed.
Next up was a wooden base, engraved with their wedding date, done on the cnc
Here are the two finished together.
Here are the different sides of the lithophane lit up.
Thats absolutely fantastic. An amazing piece of work.
Wonder how a Xmas tree would come out and something like say a bear standing and a moose on other side.
I think u on to a novelty that would sell.
Thank you all, been a fun project.
This was the 3rd attempt, as the first two had skipped steps (8 hours for each print). Brent mentioned that I may have the belts too tight. After playing with the bed, moving it back and forth, then loosening the belts, I did find I had a little resistance on my Y axis, which is the one that skipped. I also slowed down the acceleration and lowered the jerk values a little. Doing all of that seems to have helped add some smoothness to some other prints I've done since as well. :thumb:
