Tom Bussey
- Nashua Iowa
I sold my work bench so I have to build a new one. This will be my fourth and hopefully the last bench I build for myself
Okay, so where does one start when making their, first or last, bench? Probably the most often asked question I see asked on wood working forums, is how high do I make my bench? The answer to that this question is how tall are you? But this is not the place to start, it is only one of the many details. The first question should be how is the bench going to be use. As on can see I prefer a cabinet makers style bench.
How the bench is going to be used and the actual size of the top is the first consideration. And only the person that is going to be using the bench can answer that question. A wood carver, a person who only makes toys, a cabinet maker, and any other disciplines that was left out, will all have different size and height requirements.
First off the actual size, foot print if you please, should fit the environment. There are lots of plans from magazines, books, and so on out there on the market. And they all want to sound authoritative on the subject. They are all good for ideas and within reason construction ideas and details, but.
Most people can't visualize actual size, me included. I can look at an area and have a good general idea of what will fit but my wife can't. There is nothing like buying a dresser at an auction and finding out, when it gets home, it won't fit. In other words cut a piece of plywood and then fit it to the space intender for the bench to reside. It can be placed on some saw horses and a person has a temporary bench to work from.
The last bench was 78 inches long and I know that the area will support a bench that is 8 foot long. So I cut a sheet of 3/4 prefinished plywood in half. There is always a use for a 1/2 sheet of plywood so forget the other half.
Since a 1/2 sheet is easier to use than a one that is narrower I left it at a half sheet. it is easier to add a board or two to the side to make it wider. One can shorten the piece to make it fit the space for length. but do it gently. In this case it is better to shorten it four time to get it right than to add on after the fact. And you will understand this fact as I progress through the build.
To this half I am going to layout all of the information needed to build the bench, full sized blueprint if you please.
This is part one. let me know if a person it interested enough for me to continue or just for get it
