Dave Hawksford
- Outside the beltway
This is an old Swiss clock , it was in a fire. Lacquer paint cracked, gilding cracked.
Repairs begins by removing soot, then inpainting. I use gesso with added Pumice Stone #4. This sands smooth and helps with the build up.
After the inpainting is finished , I take quick dry gilding size, mix with powder dies.
The color coats are laid on in thin layers to build depth.
