Results 1 to 10 of 14
Thread: A Sphere in SketchUp
    SE Minnesota
    2,550
    Jeff Wright asked for it. Here it is. About as simple as drawing a box.
    SketchUp Sphere Video.
    15,816
    OK, now that was way cool!!
    Easy, when you know what you are doing
    Treasure Island FL
    92
    Thanks for your speedy response Dave!
    Jeff Wright
    Treasure Island FL
    Dave I was trying to duplicate your sphere. The problem I had was with the rotate tool it would only activate as blue. Is there a way to force the direction? I checked the help file but didnt see any mention of how to get the tool to display the axis you want.
    Keith
    SE Minnesota
    2,550
    Notice that I orbited down low before setting up the rotate tool. When I got the green protractor I held down Shift to lock the orientation.
    I finally was able to get the Green Protractor. (Would be handy if you could just specify to rotate about the green axis) Then I completed the sphere. Note this was my first success with the follow me tool. Thanks Dave.
    Keith
    SE Minnesota
    2,550
    Glad you got it to work.
    30,237
    Very cool Dave. Not only the sphere itself, but the other little tricks like locking the orientation really will come in handy.
    Many thanks for making and taking the time to do the video.
    Hi Dave
    Very slick. In the rotate portion it appears the ctrl key is telling SU that you want to rotate a copy of the selected object?
    This is similar to the 'move copy' sequence?
    Does the shift key need to stay depressed to lock in the axis?
    Dan
    BTW Since I've learned magical VCB properties from you are there anyother magical Cntrl key properties?
    SE Minnesota
    2,550
    Thanks guys,
    Dan, Yes, the Ctrl key activates the copy function tied to the Rotate tool. Once the center of rotation is set, you can let go of the Shift key.
    If you want to have a little fun, try this. Draw something, select it, get the Rotate tool, hit the Ctrl key (this has a toggle function so you don't need to hold it), start rotating and you'll get a copy. type some small number for the rotational angle (15 maybe), hit Enter and type *5, Enter.
    Next, before selecting any other tools, type a large number (150 for example), Enter, /5, Enter.
    Presto! A radial array in each case. The first time the six elements are distributed around a circle 15 from each other. In the second the first and last are located 150 from each other and the remaining four are distributed equally between.
  1. First try at a hollow sphere
    By Stephen Bellinger in forum General Woodturning Q&A
    Last Post: 05-09-2010, 02:42 PM
  2. Sphere Turning Tutorial
    By Matt Hutchinson in forum General Woodturning Q&A
    Last Post: 03-16-2009, 01:42 AM
  3. Walnut Sphere
    By Matt Hutchinson in forum Lathe Project Showcase
    Last Post: 03-15-2009, 08:15 PM
  4. How to turn a Sphere
    By Matt Hutchinson in forum Tips and Tutorials
    Last Post: 03-15-2009, 06:55 PM
  5. Finally made a sphere....
    Last Post: 04-14-2008, 07:21 PM
