allen levine
- new york city burbs
without a computer hooked up to router to cut out stars, not sure if this is worth any more effort to make the other 2 I intended.
maple, maple dowels, sapele, purpleheart, simple glue ups, do one, trim up, joint, glue next glue up. used an awl to tap out 50 starter holes, used 5/8 dowel in one, 1/2 in in another.
need some more oil. will attach rubber feet with stainless steel screw on bottom when finished.
Im going to continue making a few more boards, got the drum sander in the garage and out of the shed, so before I put it away, Ill use up some of the purpleheart and sapele I have.
