Results 1 to 3 of 3
Thread: Problem Push/Pulling A Rail
    Treasure Island FL
    92
    In the attached photo of a rail I created, I am having trouble changing the length of the rail. Looking at the end, you'll see that the rail appears to be comprised of many smaller parts. When I try to push or pull to change the length, each area needs to be altered and some of those areas won't move. How can I make a rail with a profile edge such as this ogee where the end of the rail appears as one continuous surface and will react to the push/pull tool appropriately? Any help is appreciated. Note: The actual SU file is too large to post. I could email it to you.
    Jeff Wright
    Treasure Island FL
    SE Minnesota
    2,550
    Push/Pull is the wrong tool, Jeff. Use the Move tool instead. Look at the video clip. Sorry, this one is silent. The important thing is to use a left to right selection box around the geometry you want to move.
    Treasure Island FL
    92
    Excellent!! Thank you.
    Jeff Wright
    Treasure Island FL
  1. Push Button
    By Les Elm in forum Flatwork Project Showcase
    Last Post: 02-21-2013, 07:07 PM
  2. Push and Pull
    By Bill Satko in forum Off Topic Discussion
    Last Post: 02-13-2012, 05:37 PM
  3. Tip for pulling nailed drywall off for reuse
    Last Post: 10-10-2011, 11:41 PM
  4. Push Drill - $30
    Last Post: 11-04-2008, 03:27 AM
