Towards improved skew control.
Ryan Mooney
I believe based on some experiments that sharpening your skew on a stone instead of (or in addition to) grinding it will yield improved tool control. I don't have a sufficiently large sample size to support this yet but the bit of anecdotal evidence I've gathered seems moderately compelling. I would be interested if anyone else either already knew this, or can give it a try if you've found the skew tricky to see if it helps at all.
To start with I basically never grind my skew, but instead use those little trend diamond paddles for day-day sharpening so hadn't really put this together in my head before.
I was messing around with it last week and decided to regrind the edge a little bit differently (same sharpening angle but just changing the "skewed" direction a smidge)... Well boy howdy it was suddenly spiral catch city! Especially when trying to turn beads, planing was ok but rolling any curves was not happy.
Took it back over to the diamond paddles and sharpened it a bit more with them which reduced the hollow grind a little and it settled right back down nicely. This was with the same basic included angle on the sharp bits and not changing the shape of the rest of it (or the height of the tool rest .. which can also make a very large difference).
My hypothesis is that a hollow ground bevel doesn't provide enough support behind the cutting edge and sharpening it on a flat stone/diamond gives just a wee bit of extra support behind the edge which helps keep the edge from rotating to quickly into the stock. You can also get the skew sharper by honing than you can with ~most~ grinders which I believe also helps, I do notice that if I've been skewing around a while the probability of a backwards spiral catch goes up and then back down once I sharpen things up again.
So if you're still fighting backward spiral catches with the skew try honing the edge on a bench stone or diamond paddle or.. whatever you use for flat blade sharpening. It doesn't take a lot, less than half a millimeter of flat behind the edge seemed to make a pretty measurable difference.
I also repeated the experiment once just to see and it seemed to have the same behavior (grind - whee many catches, then sharpen on the diamond paddles and great joy).
The effect is very likely larger or smaller depending on how steep of an angle you grind your skew at. I like mine pretty poky so I suspect that may increase the effect somewhat.
I ran into problems with my skews when I would try to sharpen them on the "slow" grinder which spins at 1850. Even on a finer grit wheel. I ended up just using that to reshape my goofs with it and using those diamond paddle hones like you are using, Ryan. After I bought that 110 rpm wet sharpener with the 220 grit wheel I tried it. Now some turners think I am nuts because I rarely use a sharpening jig. I mainly do it freehand. Not bragging but I have fairly large muscled up arms and shoulders from constant weight lifting and holding a skew or gouge steady is no problem. Sharpening my skews on the wet grinder works well. And, the edges hold well. I still do the touching up with the paddle hones, though. They are quite the useful tools. I use them on the gouges as well. If someone does a lot of turning I really recommend one of those real slow wet sharpeners. And, the hones.
More than the grind, the tool rest setting is most important to my students. The tool rest predominantly is set so the tool is at midpoint of the turning. I have my students set the tool rest high (3/4 or more high) and this greatly reduces the number of catches. On a side note, to low of a tool rest is probably the biggest culprit in any of their poor turning, blow up situations.
I believe it's Eli Evisera who pushes the idea of creating a convex grind as opposed to a concave grind on a skew. As I recall, his theory (much like your hypothesis) is that you get more of the bevel supporting the cutting edge that way. He also hones on a felt wheel charged with honing compound after getting the initial shape on the grinder. (Or was it a wood wheel? It's been several years since I saw his demo. Stu would likely know.)
Sat in on a demo with Alan Lacer a couple of weeks ago. He uses skews for just about everything. He grinds then hones. Gets them scary sharp. And he cuts high on his blank, too. I've been honing only, but learned from him that I need to do some reshaping on the grinder then hone better and raise my tool rest.
A lot of my experience has been stated here already. I too have found hollow grinds more "iffy", so I made a custom sharpening machine that allows me to quickly sharpen a skew without a hollow grind. Of course, honing is alays good.
I agree with the tools rest comments. If its too low then certain types of cuts become very problematic.
Another thing that is absolutely critical to this conversation is the rigidity of the tool rest. I know, Ryan, you did your experimentation with a consistent setup so this isn't directed to your experience directly, but most tool rests suck. I often recommend to turners to practice technique over the post before going to the end of a 12" rest. If you do well over the post but not at the end of the rest chances are you have too much flexibility/bouncing/vibration in the rest.
- Hutch
