Results 1 to 10 of 12
Thread: For you turners
    17,515
    For you turners
    ok i dont have a spinny thing yet but i do have the desire in the future, so i am trying to get the right space and DC for one. if you folks have seen my layout .skp file in a earlier post i was thinkun of puttin it next the double doors that open to the wood storage room. the door would open against it. i know those critters make alot of chips when you get them workin right. so my question is ,,would a port in the floor near the lathe be sufficient? and then the room needed for one would be? just rough idea would be helpful steve .A has a old oliver that is around 58" long and he said around 18" deep so in my mind i could put the tail towards the dbl doors and let the door open against when needed, while workin on it i would have the doors closed so would that be ok to do so in your opiion.. stu you dont count you do things in a shoe box already i need more room than that. thanks for the help.
    larry....my little Jet VS Mini with an extention sprays a 6-7' wide area with curlies and saw dust........it's about 48" from the head stock to the end of the bed extention......You couldn't have too many or enough DC openings around it.
    30,225
    When I get a lot of wet curlies, I tend to sweep and scoop them up manually instead of sucking them into the DC. If I suck up too many long wet shavings, they tend to wad up in a ball around the impeller blades. I do use the DC with a Big Gulp scoop for sanding, and it works pretty well, except when I use the air hose to blow out the inside of a hollow form. That tends to shower the area pretty good. I also use the Big Gulp when I'm turning dry wood. It doesn't catch a lot of the chips, but is does create an airflow and gathers most of the dust.
    Michigan
    2,436
    Actually Larry, the old Oliver measures 54" in length, 24" in width with the added electronic box.....sorry if I typed in the numbers wrong when I sent you the PM.
    17,515
    thanks guys, sounds like i might be better off sweeping ,,i remeber mr C sayin that wet shavings arent good on DC because of CLOGGIN. so the postion should work i think.. naw steve i just wrote it wrong close is good please dont beat me master
    15,811
    Larry, you got a coal shovel
    Seriously, that is about the best thing I've found, after the shoveling, a broom.
    For sanding sand such, on DC port is enough, for that it works well!
    Welcome to the abyss!!
    11,899
    My DC system. I need to use it one of these days.
    Goodland, Kansas
    4,834
    Larry I just use one of those old wheat shovels. Steve knows what I am talking about. They will scoop a lot of curlies.
    Bernie W.
    My kids clean up the mess for me. Who knew that they would think that it is fun.
    17,515
    looks like
    the shovels have it,,will have to see if i can talk steve A outa one he dont use them anymore well maybe he does for his corn burner...
  1. Attention All Turners
    By Nancy Laird in forum General Woodturning Q&A
    Last Post: 03-13-2009, 03:35 PM
  2. Hey you bowl turners...
    By Bill Satko in forum Lathe Project Showcase
    Last Post: 12-16-2008, 02:45 PM
  3. For the pen turners
    Last Post: 10-15-2008, 02:33 PM
  4. Any top turners out there?
    By Curt Fuller in forum General Woodturning Q&A
    Last Post: 07-04-2007, 02:09 PM
  5. Sanding tip for Turners
    By Alex Reid in forum General Woodturning Q&A
    Last Post: 12-16-2006, 12:48 PM
