- Constantine, MI
Sometime in the mid 80's my brother purchased a Klockit schoolhouse regulator kit. Our dad had recently finished a bucket list item for himself, a grandfather clock kit that turned out quite well. I can't speak to the quality of the grandfather clock kit parts, but I can attest to my dad's skill. My brother, however, seems not to have the woodworking gene. He excels in musical ability, but woodworking, not so much.
So, way back in the late 80's he handed me the partially finished kit and asked me if I could "fix" it. After sitting on it for several years I packed it up and moved it from my then home in NJ to Idaho. There it took up space in my shop till my recent move to Michigan. Now, after being here a year, I think it is finally time I got to fixing his clock. Sorry Brent, you will need to send the 'Procrastinators Cup' to me in the mail.... whenever you get around to it.
First a few words about the quality of the kit itself, it sucks. Miters are not spot on, mitered joints are assembled with those corrugated staple things that I detest, and, this is a real shame, the sides of the carcass, which are only a bit over 3 1/2" wide, are made from glued up panels! Forget about any grain matching.
This is what passes for a M&T joint,
Combine low quality parts with less than craftsman level skills and you have a recipe for disaster.
I quickly gave up any hopes of fixing this thing and decided that it would be easier, and better looking, if I just built the whole thing from scratch.
The first order of business was to see it I could recreate the moldings. It took a little experimentation, a full day in the shop, and four different router bits, but I think I came pretty close.
Next on the list was to recreate the carcass from some fine air dried Michigan chocolate courtesy of my neighbor Tom Niemi.
In the next few days I'll glue up the case (using glue blocks instead of staples) and attach moulding.
