Bob Beasley
I'm getting started on my kitchen cabinets. The uppers will have a 36" high cabinet with a 16" one on top of that. The 16" one will have a glass door insert and have lighting. My idea is to build one 52" box and use a divider, an extra bottom, at the bottom of the 16" one to split it into two cabinets. The face frame would have a matching cross piece to make it look like two separate cabinets. My thoughts on this divider is to cut a 1/4" slot into the 3/4" sides and slide the divider in. Is this a good approach?
I'm also wondering about the lighting. My doors have little bumpers that prevent wood to wood contact when closed. Will light spill out between the face frames and doors? Same question about the divider, will light leak down to the bottom cabinet?
Cabinets are 3/4" pre-finished on one side plywood boxes with popular face frames. Doors are overlay, shaker style.
Thanks!
Thanks!
