Results 1 to 10 of 10
Thread: A Reply to Jeff Wright's CutList Question
    SE Minnesota
    2,550
    I tried replying in the thread but I would get a message indicating my post was long enough and that I need more than 5 characters. Must be something with the forum software is screwed up.
    Quote Originally Posted by Jeff Wright
    That cutlist plugin is powerful!! All the more reason to carefully name the component parts with something meaningful so that when the cutlist prints out it will be easier to decipher. Yes, indeed.
    Question: A couple of the parts printed with approximate sizing, using the "~" symbol in front of the dimension. Why is that? It must be due to the way you drew the parts. To what do you have Precision set? (Window>Model Info>Units) Are parts with the apporximate dimensions drawn off axis? When you draw a part at an angle to the axes and make a component of it, the bounding box will be on axis and the plugin, because it reports the size of the bounding box is very liekely to display and approximate value. You might want to confirm whether or not those components are on axis. Turn on color by axis under Styles>Edit>Line Styles. (Click on the little wire frame box under the Edit tab in the Styles dialog.) There are probably some other reasons that could cause the problem but it isn't 6 am nor have I had my coffee. If you want to send me the SKP file, I'll take a look at it. PM me for my e-mail address.
    Treasure Island FL
    92
    Thanks Dave. I have units set to fractional and accuracy of 1/64's. I enabled the axis edge color option and see nothing except the three axis colors - blue, red and green.
    Jeff Wright
    Treasure Island FL
    Kansas
    417
    Does the cut list just look like text when you use that plug-in or does it seperate it out in boxes with the component names?
    Thanks
    Rise above the rest
    SE Minnesota
    2,550
    Aaron, the cut list plugin generates a CSV file. It can be opened in Excel as a table.
    Treasure Island FL
    92
    Quote Originally Posted by Aaron Beaver View Post
    Thanks
    Here is an image of one of my recent cutlists. Hope it helps.
    Jeff Wright
    Treasure Island FL
    Kansas
    417
    Quote Originally Posted by Jeff Wright View Post
    Jeff, did you open that in Excel and then make the titles or was all of that in the csv file? Guess I could just try a simple piece and see how it works, they have to be compents right?
    Rise above the rest
    SE Minnesota
    2,550
    The headings are generated by the script and yes, you need to have components for it to work.
    Treasure Island FL
    92
    As Dave said in his reply, yes . . . all that you see is generated automatically by the plug-in. With SU, I have gone from using just a sketch on the back of an envelope to taking my time to design the piece using SU. It is like a pre-build exercise. It forces me to think through the design of each joint and dimension choices. Now, with the cutlist plug-in, and can generate a list of sized materials and enter them in CutList Plus and save time and money buying materials.
    Someone on this or another forum mentioned that he has gotten the bid on every project he has quoted on using SU. Judging from my wife's pleasure at viewing our intended family room cabinet renovations in the SU rendition, I can easily see why he has been so successful. Few of us are able to visualize the unseen in any meaningful way.
    Jeff Wright
    Treasure Island FL
    Kansas
    417
    I would love to use SU more but after sitting at a computer for 10 hours a day at work I somtimes don't feel like using one at home for more than 2 minutes. Wish I did so I could learn and use SU more, some nights it doesn't bother me, so mostly that leaves weekends.
    Rise above the rest
    17,515
    just give it a try,arron
    i too spend to much time in frt of one but using one for somethong you enjoy is differnt and sketchup is darn helpful added to the mix dave richards and its winnun combination.. it helped me out alot in my shop project.. being able to look at all the angles and postioning tools in proper porportion willallow me to move in and know that this goes there and that goes well where it will fit so the next rainy day set down and play with it and get to know it as a freind and not another foe!!!
  1. My reply
    Last Post: 03-19-2013, 10:42 PM
  2. Delphi Cutlist question.
    By Randal Stevenson in forum General Woodworking Q&A
    Last Post: 03-07-2011, 04:21 PM
  3. question for Jeff Horton
    By John Williams in forum Old Iron
    Last Post: 05-29-2007, 05:31 PM
  4. Jeff Wright
    By Steve Clardy in forum Welcome and Introductions
    Last Post: 11-17-2006, 07:38 PM
