Results 1 to 2 of 2
Thread: Sketchup Arcs
    Kansas
    417
    Sketchup Arcs
    Way to move only one end of them. I tried selecting it (made it blue) and then use the move command but it moves the whole thing. Didn't know if there was a way to get the "endpoints" to show up where I can just stretch it.
    Rise above the rest
    SE Minnesota
    2,550
    Aaron, you can't just drag the end point of an arc. You have a couple of alternatives, though. You can select the arc and use the Scale tool to move one end of the arc. If you stretch a circular arc you end up with an elliptical one. If you can start with a parabolic arc, draw a Bezier curve set to 2 degrees. Then you can select the curve, right click and choose Edit Bezier curve and move the end point as desired. Because Bezier curves can be drawn in 3D, I would draw the curve on a large face if I wanted it to remain a 2D curve.
  1. Sketchup to DXF
    By Darren Wright in forum Designs, Plans and Sketches
    Last Post: 11-24-2010, 07:24 PM
  2. (Re)Produce Accurate Arcs
    By Frank Townend in forum New Tools
    Last Post: 10-31-2008, 09:49 AM
  3. Need Help with Parts with Arcs
    By Ken Close in forum Designs, Plans and Sketches
    Last Post: 12-13-2007, 12:00 AM
  4. An Example from SKETCHUP 6
    Last Post: 01-13-2007, 12:32 AM
  5. SketchUp 6 Pro
    Last Post: 01-09-2007, 11:50 PM
