Results 1 to 2 of 2
Thread: Picture board?
    Johannesburg, South Africa
    18
    Picture board?
    Hi
    I wasnt sure where to ask this.
    Context:
    When framing pictures. There is the picture itself, a frame and a cardboard insert that is sandwiched between the two. It is cut very cleanly at 45degrees.
    Question:
    If one does not have the special guilotine they use to cut this cardboard how does one get such a clean cut.
    My wife has requested that I frame a few pictures this weekend. I wonder if a router would work???
    Cheers,
    Stuart
    stuart, a router will fuzz cardboard......instead build a small block to hold a single edged razorblade or an exacto blade and using the held blade and a straight edge cut your matting.....tod
  1. Vertical Chest Board and Chalk Board
    By Jeb Taylor in forum Flatwork Project Showcase
    Last Post: 02-25-2012, 10:56 PM
  2. Picture Box
    By Ron Roase in forum Flatwork Project Showcase
    Last Post: 02-17-2009, 03:33 AM
  3. Picture Frame
    By Aaron Beaver in forum Flatwork Project Showcase
    Last Post: 12-16-2008, 12:13 AM
  4. First picture.
    By John Ryan in forum Lathe Project Showcase
    Last Post: 07-11-2008, 09:05 AM
