Results 1 to 5 of 5
Thread: Has anyone heard of the bearing/hot running problem with the PC7518's?...............
    Central CA
    797
    I just read that there was a problem with the bearings running too hot but there was no elaboration. Has anyone heard of this?
    I finally started using mine yesterday and I noticed that it was heating up the PRL plate. I opened the cabinet door and hot air rushed out to meet me.
    Am I going to have trouble with this now? Runout problems? Bearings seizing?
    Gosh dang caca pooey!!!...........
    Thanks, Mark.
    Custom Bonehead.
    My diet is working good. I'm down to needing just one chair now.
    "Just think how stupid the average person is, and then realize that half of them are even stupider!" --George Carlin
    Tokiwadai, Japan
    2,882
    Mark,
    Where did you read that?
    What kind of routing were you doing when you noticed the hot air?
    mark, i`ve been running 7518 routers in a production enviornment for just a couple of years.....no problems here? place a phone call to your local p/c service center on monday and ask them about any bearing trouble....i`d tend to believe a tech before internet gosip.....tod
    Steve Clardy Guest
    I have four of the 7537's, D-handles. [No longer made]
    2 are in one of my dual tables for rail and stiles.
    They have always run warm. Plate gets fairly warm also.
    These are around 7 years old now, and the heat apparently does not affect anything.
    Central CA
    797
    I first read about it from a post byKeith Outten in a thread that was asking about router recommendations. Apparently this is an issue with newer routers. I did a search after posting this thread last night and found a few references.
    http://www.woodweb.com/knowledge_bas...erheating.html
    http://www.talkshopbot.com/forum/messages/26/3961.html
    PC is aware of this from what I can tell.
    Greg, I was running a straight bit and trimming some 1/8" thick edgebanding on cabinet shelves. Very light stuff.
    I'll definately call tomorrow morning and see what they have to say.
    Thanks, Mark.
    Custom Bonehead.
  1. How do you choose a bearing
    Last Post: 08-07-2014, 09:53 PM
  2. Bearing Trivia
    Last Post: 04-26-2012, 07:48 PM
  3. Ball bearing Source
    By Bob Wiggins in forum General Woodworking Q&A
    Last Post: 06-22-2011, 12:06 PM
  4. Exploding bearing bit
    Last Post: 12-23-2007, 10:08 PM
  5. Bearing question
    By Jeff Bower in forum Old Iron
    Last Post: 08-02-2007, 04:22 AM
