Results 1 to 8 of 8
Thread: Early symptoms
    17,515
    Talking Early symptoms
    well i think i am cumin down with something i started feelin it while in missouri, and it has gotten progressivly worse. so i will show you some of the symptoms and see if yuou can tell me how to treat it and possibly cure it
ID:	9097 Click image for larger version.
ID:	9098 Click image for larger version.
    can anyone tell me what i have here? it has these names on it."ZJM master"auburn newyork and then below "Clark"
    this is a 45 but dont have the rods, or the cutters,any idea of age or value?
ID:	9101 Click image for larger version.
    this a bailey no.3 great wood, again age ,value?
ID:	9103 Click image for larger version.
    this no.3 size Fulton? plain wood and made in usa,,again how did i do
    great havun abrother that is ajunk collector...
    careful there larry! this is much worse than spin-crack......
    17,515
    Wink Yup i think so
    its steve's fault, he said i needed a potty and while in his one long afternon i saw how he had his decorated so i figured mine should be decorated likewize or it wouldnt work properly i refurbished a 192 yestrday and while doing so i was thinkun of my great great uncle that at one time used this very plane and to think that agin sometime in the near future i will be using it again i have learned to respect the hand work of the early craftsman.. they were some skilled folk...
    3,147
    Its called oldhandtoolustanoses there is no known cure & is felt mostly in the hands & heart.
    It makes me cry for all the old tools in glass cases never to be use again accept as decorations.
    17,515
    hey bart or any others have any idea what the wooden one is or how old, value?
    3,147
    It looks like a fence guided plow plane. Check the toe or heal to see if there is anything stamped into the wood.
    17,515
    it does bart,
    i had it wrote on the post,, ."ZJM Master" Auburn, NewYork and then below "Clark"
    3,147
    Sorry Larry I should have gone back & re-read your first post.
    Check this out.
    http://www.planemaker.com/articles/plow.htm
  1. i may be starting a little early....
    Last Post: 05-06-2014, 10:46 AM
  2. Early fathers day
    By Alan Bienlein in forum New Tools
    Last Post: 05-09-2010, 04:17 AM
  3. What's to early ?
    By Gene Miller in forum General Woodworking Q&A
    Last Post: 12-27-2008, 09:40 AM
  4. Forced to log on early
    By Brian Kight in forum General Woodturning Q&A
    Last Post: 09-23-2008, 07:28 AM
  5. a bit early.....
    By tod evans in forum Off Topic Discussion
    Last Post: 12-24-2006, 02:39 PM
