Results 1 to 6 of 6
Thread: question for Jeff Horton
    Long Beach, CA.
    17
    Jeff, or anyone, I would like to restore my Craftsman drill press. I have started disassembly. My question is, how do you remove the tags without destroying them? They are held on with small "rivets" I guess. Not sure if that is the right name for them or not. Thanks for any help you can give me.
    John
    WNY, Buffalo Area
    873
    John,
    Might have to drill the rivets out. Then when you are done with the restore, pop rivet it back on, or put it on with small screws.
    just my 2 cents. Maybe Jeff will have a better idea.
    www.tinyurl.com/thewoodshoppe
    Long Beach, CA.
    17
    Thanks Sean, I considered trying to drill them out but the head on them is very round, I'm afraid drill will skip right off. I may end just grinding them down very carefully.
    John
    WNY, Buffalo Area
    873
    Thats an idea too. If you had something like a Dremel, you might be able to grind them off with more precision than with a drill.
    The Heart of Dixie
    4,268
    EASY!! Of course I am assuming they are the same as mine and probably are. Clean the dirt off from behind the rivets and see if the hole isn't drilled through. I will bet it is. Is so, then it is a drive screw and just take a small pin punch and tap them out. SAVE THEM! They can be reused.
    I suggest getting some zipper bags and putting them and the tags in there.
    On some machines there is a blind hole and getting them out with out ruining the tag is a royal pain. You can't hardly drill them out because they are very hard. Probably worked hardened from being forged to shape.
    Jeff
    Custom built boats and Kits
    Long Beach, CA.
    17
    Thanks Jeff, sure enough, I turned the base over and the hole is all the way thru. DUH! that's easy enough.
    John
  1. For Jeff Horton
    By randy street in forum Old Iron
    Last Post: 05-14-2007, 12:03 AM
  2. New Mod Jeff Horton
    By Stuart Ablett in forum Old Iron
    Last Post: 12-05-2006, 05:19 AM
  3. Jeff Horton--TC cab
    By Cecil Arnold in forum General Woodworking Q&A
    Last Post: 11-08-2006, 02:04 PM
