Results 1 to 10 of 12
Thread: Full Size Drill Press Question
    WNY, Buffalo Area
    873
    To start, I only have a bench top drill press. The full size floor drill press is on the list of things to upgrade to along with a 14in bandsaw.
    For those of you with a full size drill press, do you bolt it to the floor, or does its weight alone keep it in one place?
    Thanks !
    www.tinyurl.com/thewoodshoppe
    Steve Clardy Guest
    I have two floor models.
    Never bolted them down.
    Never felt it was necessary.
    Now they do get a little tipsy if you move them though.
    1,289
    Hi Sean,
    I've never bolted one down yet. I change my mind much to often as to where I want things to be.
    I'll be building a more stable base for mine though. Not to sure exactly which one yet. There are a lot of good ideas out there.
    DT
    i don`t bolt mine down, it gets shifted one way or another all the time depending on what i`m doing.
    Sean
    It isn't bolted, but it is on rollers, seems steady to me!
    http://familywoodworking.org/forums/...ght=steel+city
    Jay
    WNY, Buffalo Area
    873
    Quote Originally Posted by Jay Knoll View Post
    Sean
    Jay
    Jay,
    That Steel City DP is a beast! How do you like it?
    688
    Mine is way tipsy so its bolted to the floor. Luckily I have a nice out of the way spot for it, near the hot water heater. So I've never had to move it.
    I've seen threads where folks build cabinets on the bottom part, with the DP post running up thru the middle of the cabinet. Someday when I don't have anything to do, maybe......
    By the way, the footprint of the floor model is the same size as the footprint of the benchtop, so IMHO you actually loose space by having to give up bench area.
    Quote Originally Posted by Sean Wright View Post
    Jay,
    Sean
    I have been very happy with it!
    Jay
    Tokiwadai, Japan
    2,882
    Sean,
    I also have the Steel City press, and really like it. I have it mounted on a FoxShop mobile base. Mobile, yet stable.
    5,533
    Sean,
    I'm in the 'buy what you can use' camp. I got a great deal on my Delta 11-990 DP, it's the 12" model. I picked it up used over on SMC for $75. I'm going to put mine on a small filing cabinet I have, with a plywood stand under both to bring the DP and drawers up to a useful height. Just my plan, ymmv.
    edit:
    Also, one thing that I really can't live without, even on a benchtop unit is having the table raise and lower by crank, not just the friction fit sleeve. My mentor John had a floor Craftsman without the crank, and that showed me that I really wanted a crank lift on my first real DP.
    -Ned
  1. Drill Press Question
    By Allen Bryant in forum General Woodworking Q&A
    Last Post: 04-13-2014, 01:26 AM
  2. Drill Press question
    Last Post: 12-18-2010, 12:10 AM
  3. drill press question
    Last Post: 07-18-2008, 01:45 PM
  4. Full size Drill Press mobile base
    By Don Taylor in forum General Woodworking Q&A
    Last Post: 11-10-2007, 04:54 AM
  5. Drill Press Size Clarification
    Last Post: 08-15-2007, 10:43 PM
