Results 1 to 10 of 20
Thread: Workbench Finish?
    La Habra Hts. CA
    399
    Workbench Finish?
    I'm taking apart and redoing my old Veritas workbench. It's probably at least 12 years old. Does anyone have recommendations on what type of finsih I should put on the top? Also what about sides, legs, strechers etc. It's solid maple.
    Doug
    3,147
    Watco if you need to touch it up later its easy just sand a little or use scotchbrite & wipe the dust away & wipe on the Watco. Remember its a bench not fine furniture. Please be a good boy & make lot of fine furniture on it.
    La Habra Hts. CA
    399
    Thanks Bart,
    I've heard of Watco...but isn't there different types, stains etc? I'm not really up on all the current finishing processes. Could you elaborate a little.
    Doug
    30,230
    I think Bart's referring to Watco Danish Oil. I know a lot of guys just go with boiled linseed oil (BLO) on their benches. It offers some protection, but is very easy to touch up down the road. If you're looking for something more impervious and tough, something like water-based poly (like Minwax Polycrylic) would work, but future touch-ups will show up a bit more. (But it's a workbench, so that may not be important to you.) I've used Polycrylic on a number of my jigs and sleds around the shop, and so far haven't had a need to fix any worn spots. It's tough stuff.
    Charlotte, NC
    1,487
    Danish Oil is what I used. It's held up quite well, easy to apply and allows for pretty easy cleanup.
    3,147
    "Bart is referring to Watco Danish Oil." You just wipe it on & work it in a little & wipe it off & its quick to touch up.
    I used Fruitwood Watco on my bench.
    Woodnshop URL.
    http://www.woodnshop.com/Watco_danish_oil.htm
    By the way thats a cute pup. What breed is it?
    doug, i use lacquer........no specific sheen, just what`s in the gun if i remember. my bench gets beaten-n-abused so having a finish that will melt into itself that i use on most projects is the easiest way for me to keep it kinda up........tod
    Toronto, Ontario, CANADA
    2,332
    The problem with many of the suggestions is that the veritas bench already comes with a heavy finish. Unless you are prepared to sand off that finish, you need to touch up the bench with something that is compatible. You certainly can't just apply Danish Oil or any other oil over the existing finish.
    I think that the existing finish is lacquer, but you should check with Lee Valley.
    Cheers, Frank
    La Habra Hts. CA
    399
    Frank I took the whole thing apart and planed it down just enough to clean it up. I just want to get the whole thing sealed.
    Doug
    La Habra Hts. CA
    399
    Thanks guys I will look into the Watco oil and the Minwax.
    Doug
  1. Workbench - PIP
    By Rich Aldrich in forum Flatwork Project Showcase
    Last Post: 12-22-2008, 05:33 PM
  2. PIP - Workbench
    By Rich Aldrich in forum General Woodworking Q&A
    Last Post: 11-04-2008, 11:36 PM
  3. Replies: 1
  4. Workbench - Dog and Finish Decisions
    Last Post: 04-16-2008, 02:22 AM
  5. To finish or not to finish - That's the question!
    By Bruce Shiverdecker in forum General Woodturning Q&A
    Last Post: 01-10-2007, 04:22 AM
