Results 1 to 10 of 14
Thread: Hinged Plywood Storage Rack
    Hi everyone
    Well, I need to put something together that will hold 3-4 sheets of 5 x5 ply. It seems that my local supplier has problems with his supplier, I placed an order a week ago for a sheet and it still isn't in! So, even though I don't have space and don't like to tie money up in inventory, looks like I'm going to have to have some stock on hand to avoid project delays.
    Does anyone recall seeing plans for a rack that was hinged on one side and opened like a big door from the wall? The only spot in the shop/garage that I can lean stuff has cabinets on the wall so I need to be able to get behind the plywood.
    Thanks for the help.
    Jay
    15,811
    Yeah Jay, I remember seeing something like what you describe, but I'll be darned in I can remember where
    Sorry.....
    Central NY State
    3,375
    Jay, I think you might find it in the Fine Wwing index.
    Ken
    9,109
    I recall the unit you speak of. A 2 x 10 for a bottom and back. Fullsheet for the back and a somewhat triangled sheet for the front to allow access. Piano hinged to the wall stud with wheels out front to allow it to swing-away.
    Couldn't find the plans but the odds are you would have to adapt to your space anyway so I'd just sketch it out and have at it. I'll keep looking for you though.
    9,109
    I didn't find the article but, found someone who built one:
    Glenn
    You're the man!
    Thanks that helps a great deal.
    Jay
    Oh, now the questions start!
    Glenn
    Was there a full sheet on the back or another angled sheet? It seems to me that a full sheet would be kind of usless, since the top back corner away from the hinge would be unsupported.
    Jay
    9,109
    As I remember the plans (man, I wish I could find those for you), they used a full sheet on the back. I agree that it seems like it would be more weight and very little benefit. There were stiffener ribs diagonally across the back though if I remember.
    The hinge was positioned so that these acted as bumpers when the rig was pushed against the wall. I doesn't sound like you'll be touching a wall but I would use stiffeners just the same. They could maybe be made out of the pieces you cut off to get the angle(?).
    I'm jealous. I really wanted to go this way but then found a spot that didn't require the swing and I went vertical. I still think I would have liked the swing feature now and then when something is in my way of pulling out a piece of material. Good luck with your project.
    Punta Gorda, Florida
    902
    I agree. Even if you did not have storage behind the unit it would be much easier to get a sheet out of the back if you could swing it out. Sometimes I do not even know what is in the back of the stack.
    Can't wait to see what you come up with and how your like it Jay.
    Good find Glenn.
    Apache Junction, AZ
    26
    Rack
    I built the one shown, both sheets are angled from one sheet of 3/4 ply, used a 2x6, wish I would have used a 2x8 or wider, wheel is 4" and works good.
  1. Fire wood storage rack ideas ?
    By Paul Alford in forum General Woodworking Q&A
    Last Post: 01-12-2011, 06:03 PM
  2. Fire Wood Storage Rack
    Last Post: 10-12-2010, 02:50 AM
  3. Storage rack for wood dowels
    By Ken Schweim in forum Flatwork Project Showcase
    Last Post: 08-25-2010, 02:13 AM
  4. Commercial Wood Storage Rack?
    By Bill Satko in forum Carpentry and Construction
    Last Post: 01-06-2010, 10:33 PM
