Results 1 to 10 of 14
Thread: Let's see your blade storage!
    In the spirit of Rob Bodenschatz's 'Show me' threads, I would like to see how folks store their saw blades, specifically for the TS and CMS. I have been muddling around moving stacks of blades from bench to shelf, etc. for the last two years and it's about time I find a better solution. With a shop dog and the occasional neice or nephew in the shop, I need to think about something safer as well. Not to mention, something that protects the blades. Ideally, I would have one solution that could house both my 10" TS and my 12" CMS blades. But, please post all solutions that you like, I would love to see some pics! BTW, I looked for an already existing thread on this but could not find one - if this is a repeat, I apologize.
    thanks!
    873
    Hi Tim; the plan for this idea came from"WOOD". If you're interested, I could look for the specific issue. It will hold 12 blades. There is also an extension on the bottom which I added to hold TS inserts.
    Mack C. in Brooklin ON
    It feels great to sell a pen,
    I am a proud supporter of
    11,899
    My 'system' isn't picture worthy. A nail in the wall. Hang 'em there.
    Tokiwadai, Japan
    2,882
    Not exactly the one I'm planning on building, but pretty close...
    http://www.runnerduck.com/blade_holder.htm
    3,146
    Tim
    This is the cabinet I built to fit underneath the extension of my Unisaw it has heavy duty full extension glides on the bottom drawer. The blade storage section is a box that drops into the drawer with an area in the back or front as you desire for Dado blade sets.
    Punta Gorda, Florida
    902
    Same here except it is a lag bolt. Thin plwood between blades to seperate them. Not real handy for blades at the back but the two that I mostly alternate between are always on the top.
    9,108
    I'm with Mack but, Bart's is way-cool.
    3,146
    It may be cool Glenn but we all have our little problems in each of our shops. I would love to have some of the room & wall space I see in some of these pictures of shops.
    Grand Island, Nebraska
    12
    Tim,
    This is my mobile storage/transport solution for my 10" and 12" blades.
    Not sure if you can see in the picture but I run a piece split clear tubing around each blade.
    Darrin
    London, Ontario
    3,383
    No, no, this ain't right. Not a single post who uses drawers yet? All the storage is vertical?
    Well, guess I'd better show mine then, to round out the options.
    My cabinet must be nearly 10 years old. Actually, I should rebuild it sometime. I built it way back when I had a 9" Rockwell/Beaver saw, so it is a bit narrow for 10" blades.
    Got the idea from some magazine or other - each drawer bottom is a piece of 1/8" hardboard or plywood. you could have them ride in kerfs in the side of the overall box. I used small blocks for the drawers to ride on. (made it from scraps at the time, and that worked best for what I had)
    I like that each saw is kept individually separate, no chance at all of bumping into another one. I've seen other plans like this that have the blades just laying flat on some wood. I like this feature better: there are four small dowel pieces - less than 1/8" long - glued down. They don't have to be dowels. Just something that will keep the blade suspended a fraction of an inch above the base. I marked them in red on the photo, as they blend in to the background.
    These dowel pieces makes it easier to grasp the blade and lift it out than if it were laying flat.. And of course, a taller dowel in the centre keeps it from sliding around.
  1. Dye storage?
    Last Post: 02-09-2014, 11:41 PM
  2. TS Blade Storage
    By Paul Douglass in forum Jigs and Fixtures
    Last Post: 11-16-2013, 11:48 PM
  3. Bandsaw Blade storage
    By Ron Roase in forum Flatwork Project Showcase
    Last Post: 12-14-2009, 01:58 PM
  4. "Dado Blade Storage"
    By Lary Grassmeier in forum General Woodworking Q&A
    Last Post: 08-04-2007, 08:22 PM
  5. As The Saw Blade Turns (updated blade charts)
    By scott spencer in forum New Tools
    Last Post: 07-18-2007, 06:05 PM
