Results 1 to 3 of 3
Thread: 5mm Barrell Hinges
    5mm Barrell Hinges
    Hello all. Question when using the little 5mm Barrell Hinges for pen boxes and other little boxes how far from the back edge of the piece do you set these? I know you have to chamfer the back edge but just curioious on where to set them from the back edge. I have some info in one of Doug Stowes books but other than how to use the simple jig for placement on each side there isn't alot of info. Anyone have any instructions on this that would help?
    Corey
    33.8736N, 117.7627W
    435
    Try this: http://images.rockler.com/tech/39578.pdf
    This one is for the larger sizes, but has more detail...you can probably just scale down for the 5mm ones:
    http://images.rockler.com/tech/28555.pdf
    You've got some lee-way on that dimension depending on the thickness of the material, but the "V" of the bevel has to end up at the center of the hinge hole.
    Where are we going? And what am I doing in this handbasket?
    Thanks Lee for the links. Appreciate it.
    Corey
  1. Wooden Hinges
    By Ron Roase in forum General Woodworking Q&A
    Last Post: 03-16-2011, 11:31 PM
  2. Hinges one more time please
    Last Post: 09-07-2009, 05:55 PM
  3. hinges...
    By Dan Noren in forum General Woodworking Q&A
    Last Post: 09-04-2009, 07:01 PM
  4. Barrel hinges
    Last Post: 07-29-2009, 08:43 PM
  5. Hinges
    By Douglas Jones in forum Old Ads
    Last Post: 07-17-2008, 04:08 AM
