Results 1 to 5 of 5
Thread: Walnut Potpourri Pot
    30,225
    This little piece of walnut started as a hollow form, but the opening warped enough while drying that it ended up bigger than I wanted, so I enlarged it a bit more to fit a potpourri pot lid. It's about 4" wide by 2 1/2" tall.
    I finished it with Antique Oil inside and out, and buffed with tripoli and white diamond, then Renaissance Wax. This piece of walnut has some nice figure to it, but in hindsight, I turned it upside down. The bottom has the best grain of the whole piece. (At least the inside looks very nice.)
Name:	HF021 - 02 800.jpg
ID:	9396 Click image for larger version.
Name:	HF021 - 03 800.jpg
    As always, your thoughts, comments, and critiques are welcome.
    s. Barrington,IL.
    127
    Vaughan very nice. Do you have a flat spot on the bottom or does the bowl spin on the round bottom? Nice curves to the bowl .
    Ken
    30,225
    Quote Originally Posted by Kenneth Lasota View Post
    Ken
    Thanks for the compliment, Ken. It doesn't show very well in the picture, but the bottom has a flat foot (concave, actually) that's about 5/8" in diameter.
    15,811
    Very nice chunk of wood, you showed it off well!
    Did you get the top piece from LV?
    That is where I got mine.
    30,225
    I think I got it from Penn State, but they are definitely all coming from the same factory in Asia. I picked up four of them last year, and this is the second one I've used. I think I'll just wait to use the remaining ones until I have another HF where the opening gets too big.
  1. Potpourri Vase
    By Bernie Weishapl in forum Lathe Project Showcase
    Last Post: 08-19-2011, 09:00 PM
  2. Walnut potpourri
    By michael james in forum Lathe Project Showcase
    Last Post: 03-04-2011, 10:54 PM
  3. Potpourri Pot
    By Tom Baugues in forum Lathe Project Showcase
    Last Post: 11-08-2010, 04:18 AM
  4. Potpourri Pot
    Last Post: 10-20-2010, 02:53 AM
  5. potpourri bowls
    By Robert McGowen in forum Lathe Project Showcase
    Last Post: 01-28-2010, 12:12 PM
