Results 1 to 2 of 2
Thread: How to draw an arch in SU?
    Atlanta, GA
    194
    I'm having trouble drawing an arch in SU where the ends stay flat in/parallel to the X axis. Here is what I'm doing: draw a rectangle, then draw an arc connected to one of the corners, then use the follow me tool to draw the arch. But the face end of the arch lifts off the X axis (as a piece of real wood would do if you bent it). Any suggestions?
    SE Minnesota
    2,527
    Charlie, could you post a SketchUp file of what you are doing so I can see? You can attach a small SKP file to your post. then I'll be able to figure out exactly what's going on.
    Dave
  1. Arch rule
    By larry merlau in forum Jigs and Fixtures
    Last Post: 02-16-2013, 05:25 AM
  2. LIDDED ARCH
    By Pete Gray in forum Lathe Project Showcase
    Last Post: 12-31-2012, 09:05 PM
  3. Draw leaf table
    By Wout Louwers in forum Designs, Plans and Sketches
    Last Post: 02-07-2010, 11:18 AM
  4. A small arch top wine cabinet
    By Robert Schaubhut in forum Flatwork Project Showcase
    Last Post: 11-17-2008, 12:59 AM
  5. Who Needs a Computer to Draw Furniture?
    Last Post: 07-11-2008, 12:35 PM
